Old 02-06-2012, 10:11 AM   #1
XCH00N
XCH00N's Avatar
Default removing stickers
hi all im just wondering how hard is it to remove a sticker off paintwork without damaging the paint? and also what is the best method to do so?
thanks
THE SHED
Daily - BA Mk2 XR6 Turbo, Auto on 20s
Long Term Project - XB Sedan, too much to do on this one But its a 351, 4speed with a LSD 9inch (Back over home in NSW)
XCH00N is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2012, 10:13 AM   #2
flappist
Default Re: removing stickers
Use a heat gun. That usually works well just be careful not to overheat the paint.
flappist is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2012, 10:21 AM   #3
GasoLane
Former BTIKD
GasoLane's Avatar
I've heard that a hairdryer works as well.
Old 02-06-2012, 10:52 AM   #4
flappist
So what, you unbolt your turbocharger and use it to scrape the sticker off? Won't that scratch the paint?
Old 02-06-2012, 10:55 AM   #5
GULL
TuRbO
That is correct
Noise does not = Power
GULL is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2012, 11:30 AM   #6
XCH00N
XCH00N's Avatar
Now for a funny part to that the car im looking at buying which is what ill be removing the stickers off is an XR6 Turbo so that one might work, LOL!
THE SHED
Old 02-06-2012, 11:47 AM   #7
Shonky.
Shonky.'s Avatar
depending how old it is and what kind of life it's had, you may encounter a difference in weathering of the paint (as long as it's thick enough you should be able to correct it though - just another thing to think about)
Shonky. is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2012, 12:35 PM   #8
Gavin Thomas
* 1973 ZF Fairlane 500 *
Gavin Thomas's Avatar
Heat gun usually does the job - but if it is extra stubborn, then a caramel wheel will get the job done. ( P&P repair shops use them ). Can be attached to a electric or cordless drill.
Gavin Thomas is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2012, 12:42 PM   #9
Cashie
Cashie's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Multiple helpful contributions throughout the tech area.
I just left mine parked in the sun and picked the sticked off with my finger nails (fingers were numb for a few hours after)..
Current Rides:
2017 Ford Mustang
2020 Ford Everest Sport
Past Rides:
2017 Kia Stinger GT
2008 FG XR6 Sedan
2008 FG G6E Sedan
2004 BA XR8 Sedan
2008 BF XR6 Turbo Sedan
2004 BA XR8 Sedan
2003 BA XR8 Ute
2003 BA XR6 Sedan
Cashie is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2012, 12:49 PM   #10
sneaky
sneaky's Avatar
i have done it in the past on a red daihatsu that was about 10 years old, and there was no fading that i could notice.
hopefully if a red daihatsu of that age can get good results a newer ford should be ok.
i used a hair dryer to warm the sticker/glue up and carefully peeled it off.
-Tim
sneaky is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2012, 01:06 PM   #11
Marquis
HUGE MEMBER
Marquis's Avatar
Hair dryer, Yes
Heat gun, Never.
Like said above, sunlight is worth a go first
I would not pee on a Holden if it were on fire. I would take pics and post for your pleasure
My cruiser. 1979 Zh Marquis. "T" code 351.
My garage queen :(. 1980 TF Cortina Ghia Wagon. 4.1.
My dog. 2011 Sierra
My Daily. 2012 ZH (lol) OUTLANDER xls. 4WD CVT. Sapphire blue
Wanted
Borg Warner Lsd or centre. 25 spline
Marquis is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2012, 08:45 PM   #12
dave351cid
playing in my big shed
dave351cid's Avatar
depends a lot on the age of the sticker and how much its been in the sun / weather.
if the sticker is still reasonably fresh it should just peel off easy.
if its a bit old and harder then warm it up a little ( warm , not hot) with hair drier, heat gun ( becareful not to scorch the paint), sun whatever and hopefully it will peel off ok. may come off in bits but be patient and keep picking away (finger nails ). eucalyptus oil can help soften the glue and once you get the vinyl film off eucalyptus oil and a rag is good for cleaning away any residual adhesive. a final clean with paint cleaner or fine polish should tidy it up.
if the sticker is realy old and baked on, then you might need to sand it back and repaint.
`75 XB FAIRMONT sedan . mushroom beige, injected 351, toploader, 9inch
`10 FG XR50 Turbo ute. Nitro blue, 6 sp Auto, Leather trim.
`04 BA RTV tray back, Red, V8 auto,
`04 BA XR6 Turbo sedan. Blueprint. auto, Leather trim.
`03 BA XLS ute . Acid Rush, factory lpg, auto,
`48 TEA20 Grey Ferguson,
`62 Willys 6-230 , 4x4 light truck
`04 Yamaha TTR 250
dave351cid is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2012, 08:47 PM   #13
Kryton
Kryton's Avatar
Caramel wheel.
Old 02-06-2012, 09:08 PM   #14
AndyXR6T
AndyXR6T's Avatar
Hair dryer works a treat.... Just don't let it be yours missus' GHD... They don't like that... At all
AndyXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2012, 07:12 AM   #15
casabonka
You can call me Chris
casabonka's Avatar
bunnings sell a citrus cleaner, gets rid of any adhesive that's left over. comes in a clear bottle with blue label, works a treat.
'06 LS Focus Hatch
-2 1/4" Lukey Exhaust
-RDA Slotted discs/Greenstuff pads
-Rear Whiteline swaybay
-Lenso 18's w/Kumho rubber
-Tinted Windows
casabonka is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2012, 10:39 AM   #16
coasty
XH Ute fan
coasty's Avatar
We use a heat gun at work (dealership) and have never had a problem. Obviously you need to watch what your doing. Otherwise a caramel wheel works well. Again be very careful. Very easy to destroy paint.
coasty is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2012, 05:22 PM   #17
XCH00N
XCH00N's Avatar
thanks for all the comments and help but ive been lucky and found another car and it hasnt got any on it (thank god) but now that leads to what is the easiest/best way to remove a badge off the body without damage.
THE SHED
Old 03-06-2012, 06:35 PM   #18
LoudXR6
to much rubber
LoudXR6's Avatar
sign places usually use steam mops and guns from what ive seen to remove vinyl and badges
LoudXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2012, 06:39 PM   #19
Nikked
Oo\===/oO
Nikked's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Long time member, loves Fords, sensible contributor and does some good and interesting posts.
Originally Posted by Marquis
Hair dryer, Yes
Heat gun, Never.
Why not a heat gun?
They have temperature and speed control.
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2012, 03:38 PM   #20
BOOSTEDGAZ
When in doubt-MORE BOOST!
BOOSTEDGAZ's Avatar
Heat gun is fine. just heat the area as evenly as you can and then get a corner lifted and heat as you remove. Wax and grease remover will get any residue off. Best way is to combine both methods. Park the car in the sun fo r a while to warm the panels up and then heat the stickers with a heat gun and way you go. I removed the stripes off my GTP and after a clean you would never know they were there.
BOOSTEDGAZ is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2012, 04:39 PM   #21
superfly
Go the Hogster!
superfly's Avatar
I've just used a hair dryer in the past and then used some wax to remove all the residue. That was on some stickers that were 4 years old.
Nitro XR50 - the last brand new one in OZ
first registered Oct 2011.
superfly is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2012, 09:21 PM   #22
Sunburst 335
Sunburst 335's Avatar
Use fishing line just slip it behind badge use sawing motion easy and citrus cleaner to remove left over glue
Sunburst 335 is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2012, 09:34 PM   #23
Neale
Neale's Avatar
I remove stickers with a heat gun all of the time at work as a signwriter & have never cooked the paint.
As long as you dont concentrate the heat in one spot for a long time, it wont be a probem. The sticker will burn before the paint anyway, so if you see the sticker starting to discolour then you know its getting too hot
Just remember theres no point getting the sticker any hotter than you can touch or you cant grab it to peel it off.
Neale is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2013, 08:02 PM   #24
HornGT
LIVE TO DRIVE.
thanks it was worth looking this up.Hair dryer did it for me.
HornGT is offline   Reply With Quote Multi-Quote with this Post
