Old 07-02-2013, 05:13 PM   #1
Mrs P
Default Cracked fog lamps = yellow sticker?
Just been told by my mechanic that my XR6T's cracked fog lamps are a "yellow sticker" offense (i.e. would receive a work order or compliance notice if pulled over by the cops).
Does anyone know if this is actually true? They've been cracked for ages and infact at last service it was mentioned but they didn't mention the yellow sticker. So I'm a bit unsure?!
Mrs P is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2013, 05:22 PM   #2
Jimmy_Rebel
It is a road worthy item. When doing roadworthy any cracked lenses are unroadworthy. And if you got a picky enough police officer they'd canary you for it. I've seen it some for indicator lenses.
Jimmy_Rebel is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2013, 05:23 PM   #3
Bossxr8
Peter Car
Bossxr8's Avatar
Default Re: Cracked fog lamps = yellow sticker?
It would be, but how visible is it?
If it's only visible from close up I wouldn't even worry about it because no one will notice, but if it's a big crack that's easily visible that's a different story. It's probably something you'd never get pulled over for but technically it would make the car unroadworthy.
Old 07-02-2013, 05:25 PM   #4
Mrs P
Bugger. Cheers for that. Just spent 2.5K on some major works, feels like a money pit at the moment! Hubby says he can replace them himself, is it something you can DIY fairly easily?
Old 07-02-2013, 05:27 PM   #5
Jimmy_Rebel
You have to get underneath the bar. They're tricky if you've never done them before.
Old 07-02-2013, 05:28 PM   #6
Sprint
Sprint's Avatar
if it functions its legal,if its just cracked then so is the cop.
Sprint is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2013, 05:29 PM   #7
OffRoadFalcon
"Flooded it mate?"
OffRoadFalcon's Avatar
Interesting...
I have the tiniest crack in one of the indicator lenses on the bullbar on my AUII wagon... would they seriously canary it for that?
OffRoadFalcon is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2013, 05:31 PM   #8
Jimmy_Rebel
If you got a tough enough cop they do.
I was in a car they did it on. Was an AUII wagon with sun damaged lense and it had a crack from heat damage and they chucked him a canary.
Old 07-02-2013, 05:33 PM   #9
Jimmy_Rebel
Mind you it was after he was pulled over for 'not indicating long enough in a lane change'
Old 07-02-2013, 05:50 PM   #10
svo supporter
Fixing Ford's **** ups
svo supporter's Avatar
If the crack is enough to allow light to shine through the lense, it's a canary....
IMA, most cops wouldn't bother, providing you act innocient...
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises.
Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here
Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone
Old 08-02-2013, 04:38 PM   #11
XrRabbit
Little Sammy xr6
XrRabbit's Avatar
It shouldn't I have 2 cracks in one if my fog lights. Been there for almost 2 years and have been pulled over a lot by the cops (never doing anything wrong) always random breathos and licence checks and never had them say anything to me about it.
Lets RIDE!
XrRabbit is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2013, 06:18 PM   #12
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
Just because you have not been done for it do not assume it is ok. Damaged lights are part of roadworthy
Pit Lane Performance
20 Rosella St Frankston 03 9783 8122
Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2013, 06:55 PM   #13
GasoLane
Former BTIKD
GasoLane's Avatar
Assuming it's a glass lens there's always the old........ "cracked officer? really?... Gee it wasn't yesterday. It must have been a stone thrown up by another car that did it".
Old 08-02-2013, 07:18 PM   #14
madwag
madwag's Avatar
i just had a car roadworthied. one of the items was a cracked indicator lense, and cracks in my tail light.
So interpret that as you will
WTB. Black BF front door trims, BF wagon books, terry ducting.
The Daily's Build.
http://www.fordforums.com.au/showthread.php?t=11349360
Weekender: '69 VW Notchback
http://www.fordforums.com.au/showthr...24#post4531824
madwag is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2013, 01:27 PM   #15
roberts
If the light is there it cant be cracked, just remove them till you can fix or dont bother as you cant use them unless its foggy.
roberts is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2013, 01:35 PM   #16
2011G6E
2011G6E's Avatar
I got warned for that down in Rocky in the G6E...No other traffic around, copper was in other lane a few car lengths back, I checked the mirror, did a head check, and flicked the indicator stalk to activate the "lane change" thing where it flashes three times...I was in the other lane by the time it did the third flash. Next thing it's blue lights and he pulled me over. Wife starts saying "You indicated, didn't you?', and I said yes.
Cop walks up to window, gives me a short lecture about lane changing, said I didn't indicate for long enough...I showed him the way the lane change feature worked, it flashes three times. He didn't seem to care..."That's not enough". I said "That's how it is from the factory...I can show you the handbook where it's called a lane change feature". He replied "Well the idiots at Ford have got it wrong...indicate properly next time, alright?"
Must have been a slow day...or he was annoyed at having to drive around in an Aurion...
Old 10-02-2013, 01:44 PM   #17
FGII-XR6
FGII-XR6's Avatar
the reason a crack is considered unroadworthy is they believe water can enter the light affecting the operation of the light ( I was told this by a friend who does inspections). Any crack in a light is an unroadworthy technically but minor ones are usually ignored. if the cop had had a bad day or you give him attitude you'll get a pretty yellow sticker
[SIGPIC][/SIGPIC]
Rides:
Old 10-02-2013, 02:31 PM   #18
GhiaEB
2004 TX Territory
GhiaEB's Avatar
I know it's only a small thing, but you're meant to indicate before changing lanes not start indicating while changing lanes. But at least you use yours, some drivers seem to think it optional.
Sadly the EB is dead....
Now a AWD TX Territory Daily
P6 Silver Monarch Weekender
And on 2 Wheels,
ZZR 250
Can do mixer shaft replacement on BA-BF Falcon and SX-SY, fix your heater Today. PM For more details
For sale: Heaps of Territory bits and bobs including front brembo doglegs, NOS I-design territory body kit painted offshore, also FPV 290 engine bits. FS thread here http://www.fordforums.com.au/showthread.php?t=11397826 Pm for more details.
GhiaEB is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2013, 04:45 PM   #19
LukeGT
Melbourne, Victoria
LukeGT's Avatar
Thats right, you can have a roadworthy light with a crack as long as it is water tight or still sealed basically. I do a few roadworthy's mainly on older cars and lenses are usually 'fractured' (cracked) from age, and have never had a problem with them failing a RWC.
[SIGPIC][/SIGPIC]
XB GT Restoration - http://www.fordforums.com.au/showthread.php?t=11281881
LukeGT is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2013, 05:13 PM   #20
deesun
deesun's Avatar
I have never liked the 3 flash bit, a minimum 4 or possibly 5 would be best. As for the OP post, the short answer is yes they are, the long answer is they probably wont depending on how bad they are and they definately will if you give the cop some lip and he sees it. Although it depends on where you put your lips, hahahaha.
igodabigblackshinycar and I relented and allowed a BMW into the garage.
deesun is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2013, 09:08 AM   #21
KW XRT
KW XRT's Avatar
Seems the lenses only crack when they are hit while hot.I never had a crack in either of my cars because I don't use them.Do agree though that cracks are a RWC item.The fog lights are cheap off ebay and if you drop the air dam are easy to fit.Just check the new lights when you get them to see how the clips lock onto the fog light holes they just push in but could be a paint to get out without causing damage.
Ambrose driving in Nascar and joining RPM Murphy somewhere in the V8'S.
XR6 Turbo.Championship winner.
KW XRT is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2013, 09:52 AM   #22
aussie muscle
aussie muscle's Avatar
i lost a couple of fog light due to damage, so i bought some plastic protectors. it protected lens fine, but it broke the mounting bracket (plastic), so i had to buy a new light anyway.
My ride: 2007 Falcon Ute BF XR8 Orange, MTO.
aussie muscle is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2013, 01:02 PM   #23
Lardman
If there was one having a bad day you decided to make worse, pretty much.
Lardman is offline   Reply With Quote Multi-Quote with this Post
