Q - CAR
Checked the inside measurements on my Trickflow 190 cc heads tonight ... and they measured up at 32mm wide, where the inside of my extractor where only 26mm... so i put abit of effort into correcting the problem.
![]() ANd thats where I was glad i used the remflex gaskets for they proved a good step in for my header porting. Also - for anyone who is interested, the TFS R Series manifold measure at 27.5 cm from the upper face of the lower manifold to the top breather of the BBK TB.... where the TFS track heat was approx 25 cm.
AU FORD STROKER 347 Windsor Stroked; (10:2.1) / TFS 190 heads / TFS R Series 90 manifold / Accufab 85mm Race TB / 90mm Lightening MAF / K&N 90mm pod CAI / FTI custom cam (230-236 @ 50) / Bosch 36lb inject / MSD coil + leads / ASR 8lt sump / Mcleod RST Twin Plate Clutch / Pacemakers PH4006 + 3" single exhaust / BA Premium brake pac / Pedders Xtreme coil over shocks / 30mm Whiteline sway / 3.45 LSD / Custom FG bonnet / Ghia interior upgrade / Enkie Rims - staggered / Quarter Horse tuned. Last edited by bluestripes; 31-03-2013 at 10:36 PM. |
