Old 31-03-2013, 10:19 AM   #1
Storme93
Jeep/Mercedes Technician
Storme93's Avatar
Default Headlight issues!
A while back I found out that my drivers side headlight wasn't working so I replaced it, to my surprise it still didnt work. My lights on the dash had been flickering leading up to this and now half the dash lights don't work and neither does the shifter light.
Now the left hand light also only works some of the time, I've tried buying a new headlight switch but that made no difference at all. This is really starting to frustrate me!!!!
Can anybody help???
The Ride
FGX XR8, Silhouette, Manual, 500HP, 940NM, Tune, 71mm Pulley, KPM Intercooler, BMC Twin Air Filter
Storme93 is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2013, 11:20 AM   #2
mik
mik's Avatar
Default Re: Headlight issues!
i`m not a sparky`s ******* , but i think i would be checking earths and wiring connections firstly old mate, then go on from there.
Old 31-03-2013, 12:24 PM   #3
Storme93
Storme93's Avatar
Where are the headlight earths normally run to? I don't know where to look!
The Ride
Old 31-03-2013, 01:10 PM   #4
BHDOGS
Follow the wires back from the headlight globe holder
BHDOGS is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2013, 08:41 PM   #5
Gaz
Got Ghia?
Gaz's Avatar
If you have a test light probe the plug.
If not put a bit of wire from the earth plug (should be able to poke it in the back) to the -ve battery or ground to check if it's an earth issue.
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold
2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers
Gaz is offline   Reply With Quote Multi-Quote with this Post
