Old 10-04-2013, 11:23 PM   #1
tezxr8man
Default AU 347 Tuning
has any body run into dramas tuning an AU with a 347 in it??
it has AFR185 heads 42psi injectors decent cam and all the other bits and peaces to go with it. My tuner is having dramas tuning with a tuner and the factory ECU. What is the best way to go from here??
tezxr8man is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2013, 11:26 PM   #2
BOTTLEDUP
Default Re: AU 347 Tuning
Moates Quarterhorse seems to be the unit of choice lately, where are you located?
BOTTLEDUP is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2013, 01:55 AM   #3
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For the effort put into the Australia day cruise to Albury Tech Writer: Recognition for the technical writers of AFF - Issue reason: AU Tech article.
What dramas is your tuner having? The EECV ecu is quite a powerful ECU. There is at least one example of S/C modular v8 on this site running on EECV.
I am running a Moates Quarterhorse on my 342 with AFR165s and more than decent cam. No dramas yet.
I guess more info would be handy as to what dramas your tuner is having?
Stu
2002 AU II LTD
5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust.
Quarter Mile: 13.73 @ 105.86mph
Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024
2002 XR8 pursuit 250
Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
auIILTD is online now   Reply With Quote Multi-Quote with this Post
Old 11-04-2013, 01:28 PM   #4
tezxr8man
Having dramas getting it to run smoothly and driveable with a flash tuner. lokking at going with a wolf v55o??? if he can't figure it out, He has been trying to work it out with herrods for a few days now with no solution. he said somehing about a fuel scaleing issue. it won't stop running real rich
Old 11-04-2013, 07:27 PM   #5
Cam
Stroking it...
Cam's Avatar
If he can't get a 347 running properly with a flash tuner, you need a new tuner. Although if herrods are involved it's a step in the right direction.
DO NOT fork out for a wolf..
Had: 347ci AU
Then: Stock AU fairmont wagon...'05 AWD Terri GHIA on Gas.. and a caravan..
Currently traveling OZ Travels over, follow me at http://Facebook.com/gonecaravaning
Now: Busted assed EB Wagon - 5sp and Dual Fuel.
Cam is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2013, 07:39 PM   #6
tezxr8man
I kind of ran out of knowledge when it was put together, which would be the best way to go from here???
There really isn't to many clued on people up here with v8 fords it Townsville. every1 is either LS or xr6 turbo.
Old 12-04-2013, 08:57 PM   #7
Cam
Stroking it...
Cam's Avatar
Waiting to hear back from a mate up that way, he has a turbo LS1 but will know if there's anyone up your way who is worth the trip. Is the car running well enough to drive it (sedately) somewhere?
Had: 347ci AU
Old 13-04-2013, 12:25 PM   #8
tezxr8man
not really driveable at all, idles fine but won't rev
