Old 01-02-2005, 05:08 PM   #1
Interceptor'85
Interceptin'
Interceptor'85's Avatar
Default King Low's - Back end is lower than front?
Hey guys,
For some reason my King Spring Low's look to me like the back end is lower than the front end. And the back end does seem to bounce a bit more than the front telling me the front is stiffened more than the back, maybe. I'm not too sure.
So first - Is this normal ?
and Second - If not should I stiffen the rear or un-stiffen the front ?
Thanks
'95 EF II Falcon,
'INTERCEPTOR'
'72 XA Fairmont Coupe,
'XA Muscle'
Interceptor'85 is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2005, 05:24 PM   #2
Interceptor'85
Interceptin'
Maybe it's just the rear wheel arch...
'95 EF II Falcon,
'INTERCEPTOR'
'XA Muscle'
Old 01-02-2005, 06:12 PM   #3
fairmont1998
fairmont1998's Avatar
The EF/EL can look lower at the back due to the wheel arch being lower. Measure the height of the sills at each end (where you would use your scissor jack) and see if it is actually lower.
Current Rides:
2012 KK Jeep Cherokee Limited CRD - Still going strong
2019 MG ZS Essence
1988 RD Mitsubishi Colt GL - 59kW of Fury
2022 Kia Stinger GT
fairmont1998 is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2005, 06:18 PM   #4
Interceptor'85
Interceptin'
Rear = 150mm
Front = 170mm
It's noticeable because the rear arch meets the tyre and the fron arch has about an inch clearance :(
(And no, no dead body's in the boot, ey madnc :P)
'95 EF II Falcon,
'INTERCEPTOR'
'XA Muscle'
Old 01-02-2005, 06:34 PM   #5
LUXO_8
windsor user
my car is the same, with pedders low springs
are you running standard shocks?
thats what ive put mine to
lmao at the body comment. i wasnt going to say anythnig tis time!
Old 01-02-2005, 06:42 PM   #6
lv619
lv619's Avatar
Yeah thats like mine too.
Wouldnt want the front any lower without rolling the guards though...
Me fail English? That's unpossible.
lv619 is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2005, 06:57 PM   #7
Interceptor'85
Interceptin'
Noop, don't have standard shocks, I've got Monroe GT shocks.
'95 EF II Falcon,
'INTERCEPTOR'
'XA Muscle'
Old 01-02-2005, 07:00 PM   #8
LUXO_8
windsor user
what i meant was do you have standard height or short travel shocks
i have monroe GT standard height shocks in mine.
Old 01-02-2005, 07:05 PM   #9
Interceptor'85
Interceptin'
Oh okies, sozz all I know is they're monroe gt sports shocks. Anyway to check them?
BTW Do you think the front is stiffened? They do seem compressed a bit.
'95 EF II Falcon,
'INTERCEPTOR'
'XA Muscle'
Old 01-02-2005, 07:22 PM   #10
fairmont1998
Bugger, that is quite a difference. They didn't give you V8 springs for the front did they?
Current Rides:
2019 MG ZS Essence
2022 Kia Stinger GT
Old 01-02-2005, 07:37 PM   #11
INJECTED_250
Custom user title
INJECTED_250's Avatar
looks better with the back lower than the front..... nothings worse than the back higher than the front
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2005, 07:38 PM   #12
sphell
sphell's Avatar
it's the front struts. Put a set of Pedders SportsRyder struts in the front and it'll sit about an inch lower. Plus you keep the same suspension travel. Might have to roll the guards depending on what wheels you have though. The reason for it sitting lower is cause the Pedders struts have a lower spring land on them than the Monroes.
sphell is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2005, 07:41 PM   #13
LUXO_8
windsor user
as do koni's.
should have my superlow / koni shock combo in by all ford day..... hopefully
Old 01-02-2005, 08:00 PM   #14
DentEd XR8
DentEd XR8's Avatar
Struts wont affect ride height at all unless they have a lower spring seat, like Sphell has said with some of the pedders gear, I'd be checking ya rear control arm bushes first, my car went up 10-15mm in the bum after replacing brocken bushes
Ed
DentEd XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2005, 08:36 PM   #15
INJECTED_250
Custom user title
if u get under and crack all the bolts then tighen them up again it will lower slighlty.. this wont work if u have nolathaine bushings
Old 02-02-2005, 10:24 AM   #16
Interceptor'85
Interceptin'
That's interesting about the bushings, I'll give the underside a good look over.
Thanks guys!
'95 EF II Falcon,
'INTERCEPTOR'
'XA Muscle'
Old 02-02-2005, 10:57 AM   #17
Raptor
Raptor's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For quietly going about moderating in a fair and even manner.
My ED ended up with a droopy **** end with King Low's as well. First thing I also noticed when driving was the higher rate front, lower rate rear springs. It seems to give a decent ride/handling trade off. Car shown below even with 1' taller rear rubber.
I don't agree with that INJECTED_250. :jab:
Nothing looks worse than a lower rear-end IMHO. But maybe I'm just showing my age, I love the nose-down stance that rodders and old school muscle cars have. Rubber-rake rules!
'93 XG Falcon Ute( sold ) : '94 ED Falcon Classic ( sold ) : '04 Territory SX TS ( sold ) : '04 Falcon RTV BAII ute (still in the family)
Raptor is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2005, 02:59 PM   #18
Interceptor'85
Interceptin'
Sooo true :
'95 EF II Falcon,
'INTERCEPTOR'
'XA Muscle'
Old 02-02-2005, 05:41 PM   #19
santoitaliano
BF F6, APV SR3900
santoitaliano's Avatar
hmm i reckon my car has dropped in the *** lately.. where are the bushes, where do i look,
thanks
Santo
White APV SR3900 [WIZZRD] (Click Here) [/COLOR]
Daily:
2006 Red BF F6 Typhoon
Bluepower enhanced.
santoitaliano is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2005, 05:53 PM   #20
LUXO_8
windsor user
i agree as well that having the front higher looks ghey looks like you have a few dead bodies in teh boot ey EF machine.(whats ya name btw, EF Machine is so annoyin to type out)
Old 02-02-2005, 06:26 PM   #21
fairmont1998
Although this will fix the problem, you shouldn't need to use shocks with a lower spring land with King springs. They are designed for the standard configuration. I can't see the fronts settling an inch either if it was left.
On another thought, are the springs properly seated?
Current Rides:
2019 MG ZS Essence
2022 Kia Stinger GT
Old 02-02-2005, 07:07 PM   #22
sphell
sphell's Avatar
hmmmm :yeees: Can I re-phrase that? Nothing looks more BOGAN than a nose down front and high rear end ;)
That's all very well and good but E-series aren't rods or old skool muscle cars lol ;) I agree with injected 250 :hihi:
Old 02-02-2005, 07:32 PM   #23
Yagz
agreed
Yagz is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2005, 07:57 PM   #24
hornet
hornet's Avatar
Your joking right? Lower back than the front is something you'd expect a VN full of bogans to do. I like nice and level, or a tad (10-12mm) higher rear, so when you put something in the boot it doesn't sag.
5 Speed EL Futura
140rwkw last dyno
hornet is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2005, 08:12 PM   #25
LUXO_8
windsor user
i like when the rear is about 15mm - 20mm higher than the front, on a lowered car.
how my car is at the moment, the rear looks like its lowered and the front looks like standard. must change asap
Old 02-02-2005, 08:15 PM   #26
Interceptor'85
Interceptin'
Yeah that's what happens when the car is full of my mates. Level, or a smidge higher at the back is perfecto.
'95 EF II Falcon,
'INTERCEPTOR'
'XA Muscle'
Old 02-02-2005, 08:16 PM   #27
Interceptor'85
Interceptin'
Madnc you funny bugga! My name's Matt
Yeah my front end looks standard height too, compared to the rear.
'95 EF II Falcon,
'INTERCEPTOR'
'XA Muscle'
