Old 28-03-2013, 03:52 PM   #1
numloxx
Default 2008 Focus Console Mod
Hi all,
I want to add a USB for charging to my centre console under the heater controls.
I've bought some blank replacements from Ford today (Was expecting them to cost $30 each, but only $5 each), and want to cut a hole in one, and glue a usb port into them. But I'm unsure about how to wire them, and how to go about the whole thing.
Hoping someone here has done something similar.
Another mod I'm planning on doing is hard wiring my dashcam's power to one of them blanks, but using a toggle switch similar to the rear window heater to switch it on and off etc., but having it powered only when the engine is running.
Any help would be greatly appreciated Thanks
numloxx is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2013, 04:55 PM   #2
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Default Re: 2008 Focus Console Mod
I've got my driving light switch in one of those blanks. We drilled a hole in it, mounted the switch and hot glued the blank plate back in.
With USB it has to be 5V and 500ma to meet standards.
It might be worth buying a cigarette socket to usb adaptor, pulling it apart and using the insides behind the blanking plate.
If you wired up a USB port by itself you'd feed it 14V when the car is running.
Old 28-03-2013, 05:22 PM   #3
numloxx
Cool, thanks for the reply and warning regarding voltage :-)
Old 28-03-2013, 08:11 PM   #4
casabonka
You can call me Chris
casabonka's Avatar
Jaycar might be good for those sorts of plugs - I did that when I added a 3.5mm plug in a blanking plate. Although I cheated and just went from the glove box plug rather than the back of the head unit.
'06 LS Focus Hatch
-2 1/4" Lukey Exhaust
-RDA Slotted discs/Greenstuff pads
-Rear Whiteline swaybay
-Lenso 18's w/Kumho rubber
-Tinted Windows
casabonka is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2013, 03:31 PM   #5
leakey
leakey's Avatar
Or go with one of either of these -
http://www.ebay.com.au/itm/Ford-FOCU...item3380dffd2c
http://www.ebay.com.au/itm/USB-Klink...item3a7e8201c6
XG Falcon Ute, XE Fairmont Ghia & BA Mk II Falcon SR
leakey is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2013, 04:56 PM   #6
numloxx
First one is for stereos with usb ports, second might be an option.thanks.
Old 30-04-2013, 10:04 PM   #7
lestone91
lestone91's Avatar
you will probably need more amps than 500mA alot of phones need 1A or fats charge and tablets require 2.1 A
lestone91 is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2013, 01:37 PM   #8
numloxx
Yeah thanks. I have found some Cigarette chargers that put out 1-2 Amps.
