Old 21-04-2013, 03:42 PM   #1
tasdex
tasdex's Avatar
Default whats this for ????
toiling under the bonnet ,, and found this ...
the brass threaded bit with the electrical fitting ,,,,sender ???
tasdex is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2013, 03:53 PM   #2
tasdex
tasdex's Avatar
Default Re: whats this for ????
forgot to add ,,
its a 2002 focus lr lx , with 2.0 liter zetec auto ..
Old 23-04-2013, 05:47 PM   #3
ola
ola's Avatar
What exactly are you referring to mate?
ola is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2013, 08:13 PM   #4
tasdex
tasdex's Avatar
the brass threaded nut ,,
below the green fuse.
Old 23-04-2013, 11:30 PM   #5
WILDB
WILDB's Avatar
Does it have any wires running to it, if so, where do they originate from?
WILDB is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2013, 11:43 PM   #6
Russ
Russ's Avatar
Contributor: For members who make a contribution worthy of recognition. - Issue reason: Very helpful and gracious with photoshop work to help others..
Maybe a temperature sensor ?
Russ is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2013, 07:53 AM   #7
Russ
Russ's Avatar
Looks similar to this, although I would expect this would be fitted into the inlet manifold or block somewhere ?
http://www.ebay.com.au/itm/New-Genui...-/150984176475
Old 26-04-2013, 09:05 PM   #8
p.laver
It's an under-bonnet air temp sensor to activate the engine cooling fans to run on after the engine has been switched off. This was the early fix to prevent fuel evaporation and poor hot engine starting. Fans were only activated at very high under-bonnet temps.
p.laver is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2013, 12:19 AM   #9
tasdex
tasdex's Avatar
cheers p.laver ..
just seemed odd that its just sitting there ,, and a thread on it .
Old 05-05-2013, 07:16 PM   #10
p.laver
Originally Posted by tasdex View Post
cheers p.laver ..
Yes I know it's odd, some things are when they are introduced in a rush!!!
2012 Focus ST
Tangerine Scream
