Old 01-02-2005, 10:23 AM   #1
Sterpz
Default Blown head gasket
Hi im pretty sure i have blown my head gasket god damn it, so i think i might aswell put in a new timing chain. In another thead they said to get an au11 head gasket will that fit on a el engine does it make any difference? and some guys at work are saying to take the head to the mechanics to get checked or machined, is it worth doing this?
Sterpz is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2005, 10:26 AM   #2
EFFalcon
Last warning
EFFalcon's Avatar
deffinately take the head to get checked out.
atleast to make sure its straight and get the bottom machined.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 01-02-2005, 11:52 AM   #3
Sterpz
how much do you think it will cost to get the head machined
Old 01-02-2005, 12:04 PM   #4
neb
hibernating
neb's Avatar
damn sterpz.. bloody fords always breaking down. are you going to change it yourself? i would get the head machined and pressure tested etc. to make sure its ok. you can use au steal head gaskets i think which might up the compression slightly? i'm not too sure though. no idea on costs, but let me know where you get it done.. because i need to get this ed head i have checked out as well.
neb is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2005, 12:11 PM   #5
neb
hibernating
neb's Avatar
what head gasket symptons does it have? water in the oil?
Old 01-02-2005, 12:32 PM   #6
Sterpz
i forgot to check that last night, i'll check that tonight and if it does have water in the oil i'll start working on it wednesday night, as far as taking the head to a mechanic im not sure where to take it atm, theres a place around the corner from work that i might check out.
Old 01-02-2005, 12:56 PM   #7
neb
hibernating
neb's Avatar
so how could you tell the head gasket is gone then.. whats it doing?
Old 01-02-2005, 02:39 PM   #8
Sterpz
water is coming out from right underneth the head on the side of the engine
Old 01-02-2005, 02:58 PM   #9
neb
hibernating
neb's Avatar
i just thought of something.... it could maybe be your welsh plugs they are a bit lower than the head though... but i think they can also leak coolant
Old 01-02-2005, 03:43 PM   #10
Sterpz
nah checked them they are fine
Old 01-02-2005, 05:38 PM   #11
SileNceR
02/90 EA II Fairmont
SileNceR's Avatar
mine is leaking coolant ever so slowly from the headgasket about there, used a mirror-on-a-stick (wtf the proper name is idk) and def gasket... i'm just putting up with it tho... lol
i've pulled the rocker gear and cam out of my spare motor so i'll probably pull off that head and get it worked/machined etc...
211RWKW EA
SileNceR is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2005, 06:34 PM   #12
Psycho Chicken
Psycho Chicken's Avatar
I got quoted $95 for a deck and crack test, which is what you want.
Psycho Chicken is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2005, 07:42 PM   #13
INJECTED_250
Custom user title
INJECTED_250's Avatar
you can get it done for 50-60 odd depending how how bent or damaged it is... it could be a broken head bolt....
id get
Head machined- $60 bucks
NEW bolts (au style) $30
Au Gasket set (genuine ford only) around 80-150 depending on how much mark up the dealer puts on it.
Id seriously allow a few hundred dollars in case the head is stuffed
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2005, 07:57 PM   #14
sphell
sphell's Avatar
I did my headgasket for $26 lol....still goin strong even after two turbos lol. ;)
sphell is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2005, 08:09 PM   #15
niko
likes falcon's
niko's Avatar
u always hear about "getting head checked" but wat bout blok...my new head killed my blok :( lol
www.carhubsales.com.au
niko is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2005, 08:16 PM   #16
Psycho Chicken
Getting a block tested is expensive as hell. And seems the head is the weaker metal of the two....
Old 01-02-2005, 08:19 PM   #17
INJECTED_250
Custom user title
you carnt kill ya block..... unless when u clean it u remove steel instead of gasket material :>
Old 01-02-2005, 08:25 PM   #18
EFFalcon
Last warning
EFFalcon's Avatar
an AU gasket kit is $290 retail.
it was like $180 ford employee price...
i got one a few weeks ago
Old 01-02-2005, 08:34 PM   #19
needturbo6
ooga-lagga-ligga-lagga
needturbo6's Avatar
you should also do a hardness test if its done a few k's and replace the timing chain guides as they commonly break.
needturbo6 is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2005, 08:36 PM   #20
Thanatos
E-Series Owners Club
Thanatos's Avatar
Why do you want to put a new timing chain in? Falcons are not like the four cylinders in that the timing stuff needs replacing every 100,000kms.
Unless the timing chain is noisy, then i wouldn't worry about it...
Thanatos is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2005, 08:39 PM   #21
INJECTED_250
Custom user title
i wouldnt even DREAM about changing a timing chain on a ford 6..... even when we do heads on falcons with 600,000 km .. the thought of replacing the chain never even come to mind..... unless a guide is broken
I just read u meand guids..... and yes i would check the guides with a good torch... most common to snap is the one held by the 10 mm bolt
Old 01-02-2005, 09:43 PM   #22
Smoked
Burnin Rubber
Smoked's Avatar
Sorry to hear about your misfortune mate, probably all of us, and those who havent will, suffered exactly what your goin thru. Good luck with the repairs.
Make sure you have all the correct tools before you begin work. Definately on the AU Gasket and Bolts, and if the head itself is more then $400 to repair, id start thinking about another head.
2001 AUII Forte (LPG)
K&N Air Filter
Tickford Air Intake
***Coming Soon: Clear Side Repeaters***
Originally Posted by The-ShowStoPPa
...dont get me wrong this 3.8v6 is pretty special, it does come with the popular shake rattle and roll option and the auto compliments this with the ever popular snap crackle and pop feature
Smoked is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2005, 11:00 PM   #23
MrLandau
MrLandau's Avatar
I have had to pull heads on cars with FAR less than that with timing chain issues. One went at 120000 and took out the tensioners, guides and timing case cover - as well as 12 bent valves and little marks in the pistons. I would change the timing set religiously
Shane
...Mr Landau and his low flying aircraft provided much entertainment for my daughter who stated and I quote:
"That mans car is too loud! Why is his car so loud? Is there something wrong with it?"
"No" I replied. "But there might be something wrong with the driver"...
Growing old is inevitable
:eclipsee_ Growing up is optional :eclipsee_
MrLandau is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2005, 09:25 AM   #24
niko
likes falcon's
niko's Avatar
there is a god, i do see commo headgaskets go, and ive seen more mitshushity head gaskets go than fords the v shape ones in particular!
Old 02-02-2005, 10:11 AM   #25
Sterpz
i checked the oil last night there was no water in it so i'll start work on it next week.
thanks for your help.
Old 02-02-2005, 05:32 PM   #26
needturbo6
needturbo6's Avatar
well 3.8L head gaskets go more often than AU gaskets, some Au's ive seen are at 1,400,000 and still on the original motor including head gasket, the lot really.
3.8L taxis usually have had their heads of 2 or 3 times in that amount of k's.
Old 03-02-2005, 01:44 AM   #27
Smoked
Burnin Rubber
Smoked's Avatar
Ford basically ironed out all the head gasket issues by AUII time tho. Thats why they can confidently run that limp home function. That said, i think they made a significant change from AU to AU2, coz i have seen alot of AU's with head gasket problems.
K&N Air Filter
Tickford Air Intake
Old 03-02-2005, 09:35 AM   #28
Thanatos
Thanatos's Avatar
Obviously the AU2 steel gasket is worth the extra money then!
Old 03-02-2005, 12:17 PM   #29
Smoked
Burnin Rubber
Smoked's Avatar
Spose. Im not sure, did they use stell in AU's? i have seen comparable rates of AU's and EL's at the mechanics i used to go to.
K&N Air Filter
Tickford Air Intake
