Old 06-01-2006, 10:33 AM   #1
spope
spope's Avatar
Default Valve springs!
Ok, apart from JMM, does anyone know who makes good performance valve springs to suit EA-EL heads?
Gonna be putting a lumpy cam in, and although they aren't essential, it would be nice to have stiffer ones.
I can get genuine EF XR springs for around $14 a pop, was wondering how aftermarket alternatives compare?
I assume different valve retainers would be required also?
spope is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2006, 10:38 AM   #2
TWiZTiD EA
Posts: n/a
crow make some i think
Old 06-01-2006, 12:36 PM   #3
-jjM-
-jjM-'s Avatar
i was on ford mods a while back, and just searching thur ALTEDPEFORMANCE at stuff, they seem to do the stuff
-jjM- is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2006, 12:39 PM   #4
Walkinshaw
Two > One
Walkinshaw's Avatar
crow cams offer two spring choices
Single spring with internal dampener. This uses the stock retainers and collets Binds at 0.600" should cost arround $100
Double Spring. Requires new retainers and collets. Binds at 0.650". Increased seat and nose pressure over the single sping. Cost is significantly more as you require new retainers/collets.
1978 LTD - 408ci - 11.5@120.6mph -
2004 S4 - 4.2 - M6 - quattro -
Walkinshaw is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2006, 01:58 PM   #5
spope
spope's Avatar
Cheers for that Walkinshaw.
The cam I have chosen has a maximum lift of 0.520", so i would think the single spring would be sufficient - I have emailed crow themselves to see what they would reccomend.
I am getting prices from my supplier, also, so depending on the cost difference may go the doubles to make it easier for a super lumpy cam at some point (although I doubt that will happen)
Old 06-01-2006, 08:04 PM   #6
hornet
hornet's Avatar
I've got Crane springs in my EL. Big cam too.
5 Speed EL Futura
140rwkw last dyno
hornet is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2006, 03:16 AM   #7
Walkinshaw
Two > One
Walkinshaw's Avatar
singles? doubles? do you reuse your retainers/collets? and what are the seat pressures and binding lift?
Old 07-01-2006, 12:16 PM   #8
hornet
hornet's Avatar
Singles. Using the standard retainers and collets. They were supplied with a Alted stage 3 cam, so i'm guessing high seat pressures and over 600thou binding lift
5 Speed EL Futura
140rwkw last dyno
Old 07-01-2006, 03:24 PM   #9
STOKEB
NOS Induction pssssshhhhh
STOKEB's Avatar
I no my old au head was using the XA GT Springs init, there not that expensive as well.
STOKEB - 3:7 diff gears, 3inch zorst, JMM Race Series Extractors, Custom Bottom end to suit N20, AU DEV 6 Head and Cam, Cold Air Intake, ED XR6 Manual Computer with Flash Tunner, ED XR6 Fuel reg, C10 Auto, 2800stall .
I LiVe My LiFe A bOtTlE aT a TiMe, FoR tHoSe 200 sQuIrTs I fEeL fReE.........pssssssssssssshhhhhhhhhhh
STOKEB is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2006, 04:13 PM   #10
Walkinshaw
Two > One
Walkinshaw's Avatar
the Alted cam is 608" is it not? You'd hope the Crane bind at 680"+
Old 07-01-2006, 05:32 PM   #11
hornet
hornet's Avatar
No, not 608 tho.. its 3 foot*. :P
* Substitue 3 foot for 600 thou
5 Speed EL Futura
140rwkw last dyno
