Old 16-08-2013, 04:10 PM   #1
reddevil6
Default 2.0l pinto fuel pump
Hey guys how do it replace the mechanical pump on a 2.0l pinto do it have to have engine at low cam if so how do i find low cam do i need gasket glue or sealent for the bolts an is low cam a must.
reddevil6 is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2013, 05:14 PM   #2
muzzy
muzzy's Avatar
Default Re: 2.0l pinto fuel pump
The fuel pump runs off its own small cam at low down on the engine below the dizzy, it's easy to replace 2 bolts, there is a spacer and a small push rod be careful not to loose these, pumps are common to buy 30-50 bucks
RS2000 5 speed
Twin 44idf webers + other goodies
muzzy is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2013, 11:50 PM   #3
reddevil6
Does that cam have to be in any particular position? Or does it not really matter ? And do the gaskets need special glue? And do the bolts need some sort of sellent?
Old 19-08-2013, 06:55 AM   #4
muzzy
muzzy's Avatar
To answer our questions
The pump be installed in any position , however once ou pull the pump off, rotate until the small pushrod is retracted
A general engine RTV sealant oil resistance is required
Nothing on the bolts, they are blind holes
RS2000 5 speed
Old 19-08-2013, 05:33 PM   #5
reddevil6
Ok thanks for your help
