14-01-2006, 04:06 PM | #1 | ||
Hey guys,
At the moment my cars all wired up with 1992 non smartlock EBII wiring, we are going to strip a EBII 1993 smartlock car of its wiring (engine bay and dash) wiring so i can have smartlock in my car, i have one question though, we will be taking EVERYTHING of the wiring, and replacing my wiring, so i was wondering what has to be done to START the car once ive replaced all the wiring to smartlock, as wont smartlock be a B!@$# when i first try to start it? and be embolized or something?? and also, can i use for the time being a EA 3.9L MPFI ManuaL ECU (obviously isnt a smartlock ECU) with the smartlock wiring till i get a XR6 ECU? Any comments would be appriciated thanks - Grechie
2015 FGX XR8 - 557rwkw on E85 KPM Street Fighter PCMTec Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19 Shockworks Coilovers PITLANE AUTOMOTIVE & PERFORMANCE
14-01-2006, 06:07 PM | #2 | ||
If you use the ignition switch from the car that you get the module from it should start straight away. Your car wont have a smartlock ignition switch in it. You can also swap the barrels over so you can use the orginal key as well. good luck
14-01-2006, 06:27 PM | #3 | ||
thanks NZ, so if i use the same ignition barrel it should start straight away, i dont really care bout the central locking and all, i just want it to have smartlock so in future i can get a XR6 manual ECU for it,
also i was wondering if the EA Manual ecu would work if i got the smartlock wiring?, i no smartlock talks to the ecu to see if its smartlock then starts, but if its smartlock wiring to non smartlock ecu would it matter?
14-01-2006, 06:52 PM | #4 | ||
likes falcon's
dude if your gonna do this, get a ghia loom. ;)
www.carhubsales.com.au |
14-01-2006, 07:36 PM | #5 | |||
explain why?
14-01-2006, 07:48 PM | #6 | ||
coz ghia is better;)lol
14-01-2006, 07:54 PM | #7 | ||
likes falcon's
coz ghia has every possible wire.
better to have more wires than less. means if u ever want to add on an extra feature the wires are already there.
14-01-2006, 08:33 PM | #8 | ||
Low and Loud
Nick your right on the money.
if your going to rewire the whole car to suit smartlock (well basicly the dash loom :P), you might aswell go Ghia and get Trip computer Climate control Cruise control (just need the bits for it ;)) and Ghia interior lighting options allready for you. Just saves adding the wiring later on and having some spag' of wires. I was under the impression that you couldnt use a EA ECU in a EB2/ED/EF/EL wiring setup. But you learn something every day ;)
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon : |
14-01-2006, 09:33 PM | #9 | |||
alright ill try and get the wiring loom from a Fairmont Ghia...
so youve tried a EA ECU in a smartlock and it works?
14-01-2006, 09:41 PM | #10 | ||
an ea ecu will run fine with smartlock. The other thing you could do is extract the smartlock wiring from a dash loom and overlay it to the loom you already have. thats what i did on my car when i added it. if you want the loom i can easily rip it off as all my old looms are sitting in the shed. Either way the dash has to come out
14-01-2006, 09:58 PM | #11 | |||
Low and Loud
I tried this a few times and the car barely ran
14-01-2006, 10:26 PM | #12 | ||
Because its just your car mick!
I used an eb2 non smartlock auto (!) ecu in my ea manual for ages. went fine till i hooked up the isc then the Variable Idle™ gave me the ИИИИs. |
14-01-2006, 10:29 PM | #13 | |||
Low and Loud
15-01-2006, 04:07 PM | #14 | ||
NZ, hanks i would be interested , but im after all the wiring even underbonnet as my loom atm has got a bypass wire going from someonewere in the loom to the TFI to give it power (bodgy i know) but thats the only way we could start my car wen we did this becuase there was a after market alarm in there and the wire was cut, n now i just want a whole new wiring loom with no alarm/embolizer wires so nothign looks body
15-01-2006, 04:14 PM | #15 | ||
likes falcon's
how did i manage to get an ea GL with multipoint? last 3 ea gl's ive had were multipoint
