Old 15-01-2006, 03:12 PM   #1
EBFalcs
Default balanced 4.0L
approx. how much would it cost to get a 4.0L EB-AU fully balanced, and what could a fully balanced on rev out to
EBFalcs is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2006, 03:21 PM   #2
NZ
NZ's Avatar
I havent done it myself byt i've heard its around $100 - $150 extra when you do a rebuild. Balancing wont let you rev it any harder it will still have a long stroke. The engine will run smoother and rev up quicker tho.
NZ is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2006, 03:24 PM   #3
EBFalcs
can you buy already balanced crank and pistons and that, or does it have to be done as the engines getting built. also do ACL sell balanced parts.
Old 15-01-2006, 03:50 PM   #4
stockstandard
All the parts get balanced together. Do the entire rotating assembly: Balancer, crank, rods, pistons, flywheel and pressure plate if manual. Ive reved mine to around 6300-6400. Its smooth but that is still dangerous. At that high rpm the the long stroke makes the pistons move at insane speeds. Best to keep things below 6000 IMO.
Originally Posted by casper
Yeah, the car is ugly, I can live with that.
stockstandard is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2006, 03:52 PM   #5
EBFalcs
6000 is almost another 1000rpm over stock though i'd only rev mine to a max of about 5200
Old 15-01-2006, 03:55 PM   #6
stockstandard
Stock engines should have no problems getting to 5500-5800rpm
Old 15-01-2006, 04:00 PM   #7
EBFalcs
that's impossible they have a fuel cut off a 5500
Old 15-01-2006, 04:05 PM   #8
stockstandard
not all of them
Old 15-01-2006, 04:07 PM   #9
Psycho Chicken
Psycho Chicken's Avatar
Yes but a stock engine shouldn't have any issues reving that hard if you remove the limiter.
Psycho Chicken is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2006, 04:07 PM   #10
EBFalcs
anyway, if you want it balanced do you have to get an engine place to rebuild it. and how much does that cost
Old 15-01-2006, 04:07 PM   #11
5L
[ 5L ]
5L's Avatar
my fuel cut off is at 5300
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline)
www.ignitionimages.com
5L is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2006, 04:14 PM   #12
NEG
Diabolus
NEG's Avatar
is there realy any point to reving past redline? wouldnt it be better to keep it around the max torque mark.
NEG is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2006, 04:15 PM   #13
stockstandard
Cost will vary depending on how much you get done and what tolerances it is done to. Best bet is to phone your local engine builders and find out.
Bit of a waste of $$$ if your only going to rev to 5200.
Old 15-01-2006, 04:16 PM   #14
EBFalcs
i was talking 5200 is all i rev my stock motor to.
