Old 10-11-2013, 02:58 PM   #1
thefargo
black xb
thefargo's Avatar
Default catch can on daily
probably bit of an ignorant question, but is there any advantages/disadvantages in installing a catch can on a daily driver, or even a project car that is rarely driven.
Given that neither is turbo, and the reading I've done suggests 'good for turbo cars'...thanks e-bay, any comments will be welcomed.
thefargo is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2013, 03:11 PM   #2
The Yeti
The Yeti's Avatar
Default Re: catch can on daily
Stopped the air filter filling with oil on my xf
Pariahs C.C.
What could possibly go wrong
I post images with postimg.cc (so I don’t forget)
The Yeti is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2013, 03:16 PM   #3
mik
mik's Avatar
Anything that catches a bit of blow by oil and stops it dirtying up plugs, and o2 sensor and blowing oil smoke out the exhaust sounds like a good thing to me, particularly on an engine that has seen some miles.
Old 10-11-2013, 08:17 PM   #4
Simple6
Simple6's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Tech article on rear bushes.
https://www.redline-motorworks.com/kb_results.asp?ID=8
This link is pretty good for explaining why they're good for turbo and direct injection engines, but not so required for port injection NA engines.
What mik says is relevant for benefits for NA engines, but for an everyday car I don't know if it's really worth it? Depends on the $$$ for the catch can I guess.
1976 XB Falcon 500 Wagon - BUILD THREAD
Sherwood Green | 3spd/250CI | Running Whitewalls on a 2.5" Drop
Simple6 is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2013, 11:00 PM   #5
bluestripes
Q - CAR
bluestripes's Avatar
Any suggestions on a good catch can brand / style ?
I had one on my last engine ... Only a cheapie from supercheap auto, though I was surprised how much oil it caught .
AU FORD STROKER
347 Windsor Stroked; (10:2.1) / TFS 190 heads / TFS R Series 90 manifold / Accufab 85mm Race TB / 90mm Lightening MAF / K&N 90mm pod CAI / FTI custom cam (230-236 @ 50) / Bosch 36lb inject / MSD coil + leads / ASR 8lt sump / Mcleod RST Twin Plate Clutch / Pacemakers PH4006 + 3" single exhaust / BA Premium brake pac / Pedders Xtreme coil over shocks / 30mm Whiteline sway / 3.45 LSD / Custom FG bonnet / Ghia interior upgrade / Enkie Rims - staggered / Quarter Horse tuned.
bluestripes is offline   Reply With Quote Multi-Quote with this Post
