20-01-2006, 11:42 PM | #1 | ||
i need to change my coolant in my ed. i need to know how much coolant do i need and is it alright to use normal tap water
20-01-2006, 11:46 PM | #2 | ||
Dont use tap water if you can avoid it. Get some corrosion inhibitor (or concentrated coolant) and dilute it with distilled water. That way you won't corrode everything. Big mess.
The amount of coolant - just drain the engine and radiator, fill the radiator to the top, start up the engine let it run for a while and just keep topping up. |
20-01-2006, 11:52 PM | #3 | ||
thanks
21-01-2006, 12:12 AM | #4 | ||
how much disstilled do u need
21-01-2006, 12:13 AM | #5 | ||
Around about 16 litres. Read the directions on the concentrate and then make it a little stronger. You can get the water from Bunnings fairly cheap.
21-01-2006, 08:46 AM | #6 | ||
well the system holds 15 litres of coolant,put in 1 litre of anti everything,that leaves 14 litres,,but i think they hold more.
2000 AU Wagon |
