Old 16-01-2006, 06:26 PM   #1
slamd ef wagon
Default Deep cycle batteries
wondering if these are good for stereos and car starting?
Will 40 amps an hour 12 volt deep cycle battery be enough?
AU FAIRLAINE GHIA TICKFORD I6, KINGS SL/KYB ALL ROUND, RED BACK EXHAUST, G220 RIMS
slamd ef wagon is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2006, 07:43 PM   #2
ilsautomotive
Former E-Series Member
The specification to look out for is Cold Cranking Amps. Optima batteries are popular, with the red top model around 800 CCA. Apparently the yellow top model is more suited to cars with big stereos.
http://www.optimabatteries.com/
ilsautomotive is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2006, 08:15 AM   #3
efgiar
rofl copter
efgiar's Avatar
all odessey batteries are deep cycle, i have a battery the size of 3 in my back yard, 200 amphours, sat there for 3 weeks on the concrete, then used it to jump my old mans car wen the battery died! started first go!
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2006, 08:18 AM   #4
LTDHO
The one and only
LTDHO's Avatar
I have a Optima Yellow top.
Ran it flat many times and it still holds charge.
I use it for thar reason and for the audio.
Tuned by CVE Performance
Old 17-01-2006, 08:20 AM   #5
dansedgli
dansedgli's Avatar
Which yellow top do you have Wayne?
I need to get one of these as well soon for the torry.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2006, 09:18 AM   #6
dansedgli
dansedgli's Avatar
Grr cant edit.
That odyssey one is tiny at only 3 inches thick!!
It looks like the yellow top D34 would be the best for running a stereo with the car off.
Does anyone know a good place to buy these that would be cheaper than autobarn?
Old 17-01-2006, 11:14 AM   #7
efgiar
rofl copter
efgiar's Avatar
theres a few different types of odessey batteries, the 3" thick ones arnt good but are pretty good for thier size, i wouldnt run em on a stereo setup, just run one with a big CCA eg 600-800 and run a capacitor aswell, have a solenoid in between the 2 batteries and run the trigger off the alternator so wen the car is running the 2 batteries will connect together, that way u dont flatten ur main battery if ur just sitting in a car park listening to music.
GQ patrol.
thats all
Old 17-01-2006, 03:55 PM   #8
XRated
Shoot.
XRated's Avatar
Dan, try these guys: http://www.fastfoursforumscarclub.co...s/specials.asp
They were having a sale on Optimas a little while back, but not sure if they are still on special.
20V Turbo
XRated is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2006, 05:04 PM   #9
ilsautomotive
Damn that Odyssey looks cool! I imagine it would have a serious weight advantage over Optima. Rollin, what did you pay for yours?
Old 17-01-2006, 09:26 PM   #10
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
Any of these type of batteries will have plenty of cranking amps to start the car (remember the standard battery is 460CCA or so), if you are looking at using it to run a stereo without the engine running, you need a lot of reserve capacity. And that is something that the "small" batteries don't have a lot of.
outback_ute is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2006, 11:00 AM   #11
slamd ef wagon
so is 40ampa per hour ok??
Old 18-01-2006, 10:00 PM   #12
slamd ef wagon
Old 18-01-2006, 10:07 PM   #13
gthofan
Gunna girlie-man
gthofan's Avatar
i dont know if this helps at all, but the standard battery for an eb 2 is:
cold cranking amperes: 400
reserve capacity : 95mins
Ampere Hour: 53
and the alternator is as follows:
70 amp (6cyl)
85amp(5litre v8)
or if you want a battery with more cold cranking amps, use a battery out of a new F250, they are 600 cold cranking amps!!!
WADE CAMS-- UNLEASH THE POWER!!
<INSERT WITTY SIGNATURE HERE>
Daily- 05' BA futura... work done.
Cruiser- 85' VK berlina... more work done
gthofan is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2006, 10:20 PM   #14
XR Martin
XR Martin's Avatar
Optima have ones available up to 900 Cranking amps
2004 BA wagon RTV project.
Old 18-01-2006, 10:22 PM   #15
slamd ef wagon
yer mate cheers that help it seams the battery i was looking at wont be good enough as u said the standard on is 53 amps per hour
Old 18-01-2006, 10:26 PM   #16
gthofan
Gunna girlie-man
gthofan's Avatar
what do the cold cranking amps do????
why is it the more the better
Old 19-01-2006, 01:08 AM   #17
BABOSS
BABOSS's Avatar
Cold Cranking Amps is a rating used in the battery world to define a battery's ability to start an engine in cold temperatures. The rating is the number of amps a new, fully charged battery can deliver at 0° Farenheit for 30 seconds, while maintaining a voltage of at least 7.2 volts, for a 12 volt battery. The higher the CCA rating, the greater the starting power of the battery. Mine is rated at 550CCA which is not the best, but better than most i've seen in an i6
BABOSS is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2006, 11:48 AM   #18
ilsautomotive
I have been researching the Odyssey 680 MJT and it seems a decent online price is A$225 from "www.modyourcar.com.au", or US$70 from a respected specialist Ebay US seller. It seems this is an automotive version of a motorcycle battery - its only weakness is in the amp hours department.
I'm awaiting clarification of the postage costs from the US. I would pay extra to buy from a local supplier, but not double the price or more... :(
Old 20-01-2006, 11:27 PM   #19
outback_ute
Ute Forum Moderator
Contributing Member
It is Amps multiplied by hours - 53 Ah means the battery can put out 53 Amps for an hour, or 1 Amp for 53 hours.
Old 21-01-2006, 12:19 PM   #20
TUFED6
TUFED6's Avatar
Rollin,
I can't get over that it only weighs half a kilo. If someone finds a good deal on them let me know.
- John
TUFED6 is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2006, 12:23 PM   #21
The Goodz
E-Series Firemaker
The Goodz's Avatar
I'm running 1 Exide Orbital marine dry cell and 2 Exide Orbital deep cycles dry cells... They're all around 770CCA but the marine battery is better for the stereo because it can hand out larger dosages of power for a reasonable amount of time, the deep cycles are better for smaller dosages of power but they do it for much longer... They're a tough battery, you'll do well with any of the major brands, optima, exide orbital, odyssey, etc
Alex
The Goodz is offline   Reply With Quote Multi-Quote with this Post
