Old 23-09-2014, 09:38 PM   #1
NQRS
Default electronic speedo's
Hi All,
Does the Focus or other later model small fords have electronic speedo's and if so where is the speed sensor located. Tired of my inaccurate manual one in escort and want to replace it with electronic one. Don't think transmission operated sensor will work- have a sierra 5 speed and don't know about speedo drive configuration. Any pointers? Know gps operated ones are about but want to keep round gauge in the dash type.
Cheers,
Len
NQRS is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2014, 10:07 PM   #2
Franco Cozzo
Franco Cozzo's Avatar
Default Re: electronic speedo's
Originally Posted by NQRS View Post
Hi All,
Cheers,
Len
http://www.speedhut.com/kit/GRM4-6KI...i?clid=2379554
Round ones which are still GPS - tunnels would be an issue though.
I'm fairly sure in modern cars they pick up the speed from a wheel speed sensor which might be an issue.
Old 23-09-2014, 10:40 PM   #3
NQRS
Thanks Damo- my car runs 15 inch wheels like the focus, so a wheel operated sensor might be ok. Have seen speedhut ones- bit pricey. Was looking to hit local wreckers and go from there. Might have to pick their brains if no definite info is available.
Cheers Len
Old 24-09-2014, 07:11 AM   #4
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
If you want to have some fun over a weekend and enjoy to tinker buy a bike speedo (pedal bike) and fit it.
Don't laugh - I fitted one to my Bugeye Sprite due to the same issue and you could input the tyre diameter to the MM and was still registering the correct speed at 150km/h..
$40 and a few hrs....
Oh, and works fine in tunnels too.
___________________________
Old 24-09-2014, 07:51 AM   #5
mash again
most modern cars use one of the ABS pickups, its on the rear in a ba.
mash again is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2014, 05:45 PM   #6
foxtrot3
foxtrot3's Avatar
Hi. The BA uses a signal from the ABS module. The ABS module uses both rear sensors to work out what signal to send out to the power train module. Cheers MD
HI
I'M MICHAEL
