Old 03-02-2006, 03:32 PM   #1
tidyEL
Default Yellowing headlights
Hi Guys,
I was just wondering if there was any way to stop the lights in my EL fairmont going yellow and if there is any way to clean them. Apparently it is a common fault with early EL's and EF's but I have never heard of a way to clean them...
tidyEL is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2006, 03:39 PM   #2
klawsterfobik
Bad Music and Litre Bikes
klawsterfobik's Avatar
they wont clean...
I strongly suggest The Headlight Hospital, probably the only way your going to fix it without getting new items from Ford ($300+ EACH)
www.theheadlighthospital.com.au
PM The Dok, he runs it...
XY Wagon - NAKED!
Originally Posted by Gammaboy
Anyway. Enough reality, back to the topic.
klawsterfobik is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2006, 03:52 PM   #3
BABOSS
BABOSS's Avatar
^^What he said, i bought mine for $100 ea brand new from the headlight hospital, ef. That yellowness is UV damage.
BABOSS is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2006, 03:55 PM   #4
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
If you sand them with 1500 grit wet & dry sandpaper, then 2000 grit until its smooth, and finish with a buffing wheel and a cutting compound. They'll come up pretty clear again, as long as they arent really yellow beforehand.
The reason they go yellow is from water sitting on the headlights while they lights are on, the water heats up and eventually wears away the outer coating on the plastic lenses. 2 ways you can fix the problem is by fitting lens protectors, or using HID globes, which run cooler than normal globes, might stop it too.
Old 03-02-2006, 04:00 PM   #5
tidyEL
Thanks guys, I think i will put that first on my list of things to do and it helps that dandenone is only 10 mins down the road
Old 03-02-2006, 04:12 PM   #6
klawsterfobik
=/ i thought it was the actual plastic that Ford used...
XY Wagon - NAKED!
Old 03-02-2006, 04:15 PM   #7
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
It is the ИИИИ plastic Ford used, Commodores and AU-BF use plastic lenses and they don't go yellow :(
Old 03-02-2006, 04:19 PM   #8
stockstandard
Yep. I cleaned mine up with sandpaper and polish and came up nice. Get a roll of duct tape and put a few layers on the bodywork around the light to protect it, and go over it with some fine sandpaper until the yellow is gone. I then used some sort of cut 'n' polish compound on buffer to get it clear again. Takes about 20 minutes per light and costs maybe $30 all up.
Well worth the effort. It makes a massive difference to the look of the car.
Originally Posted by casper
Yeah, the car is ugly, I can live with that.
stockstandard is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2006, 05:00 PM   #9
sphell
sphell's Avatar
Yeah it's UV damage more than water damage. Philips actually manufactures a headlight globe with a special UV filter coating especially for this reason so they don't go yellow.
sphell is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2006, 05:56 PM   #10
LUXO_8
windsor user
lol yes they do:P........ but not as bad as the EF/EL's
all can be fixed with the sanding/polishing method mentioned earlier
stupid plastic...
