Old 07-11-2014, 03:10 PM   #1
mondeo zetec
Broogg
Smile brake, radiator, pwer steering fluid
I recently purchased a Mondeo 2012 MC with the petrol ecoboost engine. Was wondering where fellow owners are getting their brake, radiator and power steering fluids from for topping up that meet Ford's specs. Have rung Ford service dept for other compatible fluids but no luck there! Any input would be welcome!
mondeo zetec is offline   Reply With Quote Multi-Quote with this Post
Old 07-11-2014, 04:46 PM   #2
ope126
ope126's Avatar
Default Re: brake, radiator, pwer steering fluid
You will find "Search" is your friend; here are a few threads - feel free to add your input!
http://www.fordforums.com.au/showthread.php?t=11391458
http://www.fordforums.com.au/showthread.php?t=11401882
http://www.fordforums.com.au/showthread.php?t=11370558
2016 (MY17) Ford Mondeo Titanium EcoBoost (Moondust Silver)...more power please!
ope126 is offline   Reply With Quote Multi-Quote with this Post
Old 07-11-2014, 05:11 PM   #3
cobrin
Challenge Accepted!
cobrin's Avatar
I had to do the long yards and get from the service manual/book the oil specifications for everything and go hunting with that in mind. Mine is a '09 MB TDCI I try and keep it all to one shop as I don't want to drive around all over the place. If you end up making a list find a place that has it all, which often the usual guys do Stupidcheap/Autobarn/Repco/Auto1. YMMV
I pretty much settled on:
Nulon Long Life Diesel Engine Oil - 5W-30
WSS-M2C913-B (Ford oil spec or better)
Nulon Full Syn. Automatic Transmission - (AWF21)
WSS-M2C924-A
Nulon Red Long Life Concentrated Coolant
WSS-M97B44-D
Penrite - LDAS (steering)
WSS-M2C204-A (Pentosin)
Nulon Xtreme Performance Brake Fluid - Super DOT 4 (M6C55-A closest I could get)
WSS-M6C57-A
So as you can see I can get Nulon for everything except the powersteering fluid. Penrite have everything having said that and I may look into it.
Go have a look at what Penrite and Nulon suggest using their search guide.
http://www.datateck.com.au/Lube/PenriteAus/
http://www.datateck.com.au/lube/NulonAus/default.asp
double check the guides on specs and make a list. I've made a txt file and have it on my phone with all consumables that I need and update as I go. Handy to keep around.
Hope it helps.
Old 07-11-2014, 05:55 PM   #4
mondeo zetec
Broogg
These posts help, thank you. Just want to make sure i put the right gear into the car. Appreciate the help!
