Old 18-01-2015, 09:58 PM   #1
deesun
deesun's Avatar
Default Battery charging
When charging a battery do I unscrew the caps on top or leave them on?
igodabigblackshinycar and I relented and allowed a BMW into the garage.
deesun is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2015, 10:01 PM   #2
Road_Warrior
Pity the fool
Road_Warrior's Avatar
Default Re: Battery charging
I usually leave them unless you were trying to jam like 20 amps in only 1 hour
Fords I own or have owned:
1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD
Proud to buy Australian and support Ford Australia through thick and thin
Road_Warrior is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2015, 10:02 PM   #3
Loosen them; no need to take them all the way off. The risk of a gassing caused explosion is extremely low (usually when some foreign body or bit broken of a cell plate blocks a cap vent) but is still a risk that can be easily avoided.
aussiblue is online now   Reply With Quote Multi-Quote with this Post
Old 18-01-2015, 10:51 PM   #4
Blem
Are you a terrorist ?
Blem is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2015, 10:54 PM   #5
Silver Ghia
Silver Ghia's Avatar
If its a 5 Amp charger (or less), no need to loosen or remove the caps. Batteries charge up when the car is driving along anyway.
Silver Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2015, 11:06 PM   #6
Itsme
Itsme's Avatar
Leave your caps on as there is no need to remove them since they are ventilated, the old rule of removing caps belong to a bygone era.
Most modern chargers monitor your battery condition & adjust accordingly.
Only time I remove caps is to check electrolyte level.
Old 18-01-2015, 11:20 PM   #7
deesun
deesun's Avatar
Thanks.
