Old 18-01-2015, 12:37 PM   #1
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Default Anyone know anything about sandboards and sandboarding in general?
My kids wanted sandboards for christmas but as I couldn't afford $300 each for boards I decided to have a go at making some. I started with a couple of molded plastic snowboards and glued some thin ply to them then glued formica to the ply. They worked a treat but had no directional stability so I made a couple of tail fins for each board, not too big, just deep enough to stop the board slewing sideways once moving. They worked ok so it was so far-so good.
Yesterday we went out into the national park to test them out and took some candles to wax the boards, as well as some proper sandboard wax and also some silicone spray that happened to be in the van. From the first run there was a speed difference between both boards, a yellow one and a purple one. The yellow one started out faster but as the day went on and as we tried the various waxes and spray, the purple board got faster and the yellow one got to the point where it just wouldn't slide at all
I'm at a total loss as to why the yellow board stopped sliding as both are basicall identical and had the same waxes used on them at different times. I thought there might be a residue issue with the yellow board so polished it back to just the formica finish but it still wouldn't go so now I'm asking if anyone might know something that will give me a clue.
Also, I noticed that no matter what was used, the boards would need the wax re-applied after every run, is that normal? Also the candle wax was faster than the shop bought board wax, is that supposed to be right ?
If anyone can shed some light on my delema I would be most gratefull.
Bushbasher
MINE- AUII Forte
Old 18-01-2015, 02:27 PM   #2
GasoLane
Former BTIKD
GasoLane's Avatar
Default Re: Anyone know anything about sandboards and sandboarding in general?
Logically this sounds about right, they are getting sandblasted at each run
Sounds a bit like buying 'Geniune' parts as against aftermarket ones. you pay more for the name and packaging ?
Old 19-01-2015, 04:17 PM   #3
Bushbasher
Bushbasher's Avatar
So nobody on the boards is into sandboarding then?................
Bugga, now I have to try and figure it out the hard way.
MINE- AUII Forte
Old 19-01-2015, 04:38 PM   #4
BradEL
BradEL's Avatar
Is sand boarding the same as skim boarding or is it different
BradEL is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2015, 05:32 PM   #5
Russ
Russ's Avatar
Contributor: For members who make a contribution worthy of recognition. - Issue reason: Very helpful and gracious with photoshop work to help others..
Basically like surfing / skiing without the water or snow
And no that's not me I'm lucky to stand on my own 2 feet let alone putting a board or wheels under them
Russ is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2015, 07:27 PM   #6
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
After a quick look on Google it seems there are many variables adding to your dilemma.
Maybe a trial and error situation testing a few brands will help.
http://www.sandboard.com/drdune/ask/ask5.htm
This guy seems to have a specific way of application working for him.
https://www.youtube.com/watch?v=4YkYCleEiK8
Falcon Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2015, 07:37 PM   #7
Bushbasher
Bushbasher's Avatar
Yer, but the dilemma is that both boards were constructed exactly the same way and were treated exactly the same with the same waxes and buffed and polished exactly the same way yet one went faster as the day went on and the other slowed to a stop eventually and wouldn't slide at all.
MINE- AUII Forte
