I want my car to look that part inside that it does outside at the moment and I can find practically anything I need, except an interior light. The light works fine but the plastic covering is just turning into powder and over 70% of it is missing. Does anyone know where i could get a plastic covering or even *Shudders* a whole new assembley. (I do have a budget so there is not a chance in hell that I can afford a genuine one) Cheers
Everyone has bad days. The cure is to drop it down a gear, put the foot to the floor and flick out the tail end. ![]() |
Let us all know what model car you have, & someone will have the answer for you.
WOGBOY69
Hmmmm
let me see .. I think its a escort.. |
a 1976 ford escort ghia 1600 weber carby
IT Drone from Sector 7G
![]() Join Date: Nov 2011
I was thinking looking in the UK may have been a better option.
Does it look anything like this: http://www.ebay.co.uk/itm/FORD-CAPRI...item51cabd8123 At 35 quid it's not cheap, it depends on how much your car to be 'original'. The above link also says to drop him a line if you're after anything in particular. |
no, it has a switch in the middle sticking out but thanks for the time you put in. (35 QUID!! REALLY!!? it is just a light people.
Might be worth your while trying a wreckers as well, it's a slightly later model but if you ask you never know your luck
![]() http://www.ebay.com.au/itm/Ford-MK2-...item2c85eeef69 or there's this as well http://www.ebay.com.au/itm/GENUINE-F...item1c4d69ad2b Last edited by Russ; 02-02-2015 at 08:51 AM. |
