I have a series 2 LV TDCi with Auto. Lately I am getting a noise that could be considered as Turbo whine, it sounds like a police siren and increases and decreases with throttle response to a point. The car is not lacking power but this noise is just creeping in and I can't explain it. I had the Auto serviced at 60,000km's so I am unsure if it might be in the transmission. Normally Turbo whine is higher pitched than this noise - just weird.
Has anyone had a noise like this with their TDCi Auto? Thanks Noel ![]()
1400 GTR Goes like it has a Kwaka up its butt |
is it a pulley bearing? The idler pulley or waterpump bearing noises will increase with RPMs
but your KLMs are a bit low for water pump issues. |
Probably the alternator. Mine made the same weird whining / police siren noise, that increased with throttle, back in 2011: http://fordforums.com.au/showthread.php?t=11325474
Probably had around 60-70,000km on the clock. |
Remove drive belt and run engine for a short period. If noise is gone, you know it is something driven by the belts, if it is still there it is something internal. Relatively easy test to try....
IT Drone from Sector 7G
![]() Join Date: Nov 2011
I have the same car, mine has what sound like a resonant momentary high-pitched whine at around 2000rpm which disappears when you're above and below. Happens in any gear under load.
Mine is a 6sp manual though... http://fordforums.com.au/showthread.php?t=11353588 |
Thanks guys, it seems noises are not something unnatural. I have to service the car soon so I will check it out whilst I am in there. My wife drives the car to work all the time and suddenly they other day when I was driving it, she say "Oh yeah, it's making this noise" hurrumph! why didn't you say something earlier... ahhhh!
I had the service done and nothing found except a kink in the air intake hose. The sound appears to be coming from the Turbo, if I stand on it the sound goes high. Not too sure what might be the problem, maybe there is a pressure leak somewhere. I does it when free revving too, it take a bit of foot pressure to get it to do it. I am going to have a good look tomorrow.
Found the noise is coming from the Turbo, now to figure out if it is terminal or something silly.
