Old 20-05-2015, 08:56 AM   #1
xgrig
Default auto window open/close
I've read on another forum that the euro LT Focus's had the auto window open/close function via the remote
apparently some guys in Australia have had this option enabled on there cars at the dealers
has anyone else had this done or know anything about it??
cheers
xgrig is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2015, 06:15 PM   #2
marg99
Default Re: auto window open/close
If you have it enabled all windows go down if you hold down the open button on the remote for about 5 seconds. the reverse is true for the lock button on the remote.
Old 20-05-2015, 09:23 PM   #3
11ford11
it is called global closing - set by ford changing parameters to suit - requires correct door modules already fitted or changed to -seems strange if it is not working IF it was already fitted to your vehicle - talk to Ford and get them to check if it was fitted already ...................
as mentioned operates by holding remote button on for extended time .............
Old 12-06-2015, 03:26 PM   #4
LordFordNZ
Requires the car to have both front and rear windows. Many Euro Focus's have only fronts, no no global open/close.
LV MKII Focus XR5 - no mods yet!
LordFordNZ is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2015, 08:45 AM   #5
pertuan
Focus on my Focus
Not sure about the Focus but on other makes, if your limiter switches for the windows are out of calibration it won't work. From the driver side, put all the windows up then hold the button up for about 5 secs.
Now: 2006 Ford Focus LX Manual in Satin White
Wife: 2013 Kuga Titanium in Frozen White
Then: 1990 Ford Laser - Assasinated by a 76 year old man who failed to give way.
Now normally when we have these races, Jeremy goes in the car and says "Powerrr" alot.... - James speaking about Jeremy (Top Gear S7 E05)
American parts... Russian parts... ALL MADE IN TAIWAN! - Russian guy in Armegeddon
pertuan is offline   Reply With Quote Multi-Quote with this Post
