Old 21-06-2015, 04:23 PM   #1
66GT
Default Fuel Gauge not working
Hi the fuel gauge in my Mk1 Cortina GT has decided to not work. I had the tank out, cleaned & painted etc, body also painted. There is only a single wire to the sender unit. Should the sender earth via the tank to body? Suggestion welcome.
thanks Joe
66GT is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2015, 05:14 PM   #2
Default Re: Fuel Gauge not working
Join the club!
At least it's only the one gauge that isn't working.
Old 21-06-2015, 05:24 PM   #3
11ford11
sender earths thru tank body -clip a jump wire to clean earth and touch other end to sender body and see if gauge works-if it now works apply an earth to the tank is probably the easiest
Old 21-06-2015, 06:37 PM   #4
66GT
Yes LG - all other gauges work.
11ford11 - I was thinking of doing exactly that, & if worked, solder a lug to sender for an earth wire. Just wanted to confirm that I was heading in the right direction first. Thanks.
Old 25-06-2015, 09:53 AM   #5
V1nn1e72
My fuel gauge in my mk2 escort stoped working as well but it turns out it is the actual gauge in the cluster that has **** itself. check that for you as well.
Everyone has bad days. The cure is to drop it down a gear, put the foot to the floor and flick out the tail end.
V1nn1e72 is offline   Reply With Quote Multi-Quote with this Post
