Old 28-06-2015, 03:46 PM   #1
V1nn1e72
Default It's a little embarrassing
Right laugh if you want but this is serious, I cannot get the back seat of my ford escort back in. Very funny I know. Please help as I need it done by Tuesday.
Everyone has bad days. The cure is to drop it down a gear, put the foot to the floor and flick out the tail end.
V1nn1e72 is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2015, 06:21 AM   #2
russellw
Chairman & Administrator
russellw's Avatar
Default Re: It's a little embarrassing
Which model Escort? The earlier ones had a horrible 'C' shaped clip that you had to rotate them around.
Russ
Observatio Facta Rotae
Old 29-06-2015, 06:48 AM   #3
V1nn1e72
Russ
It's a mark 2 ghia
Old 29-06-2015, 11:57 AM   #4
JVC063
JVC063's Avatar
The back section is held in at the top by fastening in over the parcel shelf with two nuts fitted from inside the boot. One on each side. lock under tabs on the inside of the car at the bottom. The trick is to fit it on the inside and strech it over the parcel shelf. The bottom section then is fitted under the back section and pushed back and down. the tabs then sit outside and a self tapping screw in each to hold it there.
JVC063 is offline   Reply With Quote Multi-Quote with this Post
