Old 11-02-2006, 01:21 PM   #1
chich
chich's Avatar
Default Radiator Hose + Grubby Supply Tank
I inspected my radiator hoses for deterieration and the lower hose feels pretty solid - almost as if theres a spring in there keeping it from 'collapsing'. Is this normal or is it clogged with crap?
I also need to remove the supply tank & give it a quick clean because it looks grubby.. what do you guys recomend?
chich is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2006, 01:41 PM   #2
EFFalcon
Last warning
EFFalcon's Avatar
there is a spring in there, just on the corner.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 11-02-2006, 11:25 PM   #3
John_LS1
for the tank you can put some sand and water/detergent in there then block all the holes and shake it around for a couple of minutes. then just drain it and flush out the sand should improve it a bit. if its gone really brown/rusty then it wont help much. new ones are under $100.
Old 15-02-2006, 08:10 PM   #4
oyob2003
radiator flush product should clean it up
oyob2003 is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2006, 08:25 PM   #5
svo347
AFF's 1st DM.......
svo347's Avatar
As well as CLR... Bought mine up real good.
FORD GIVING POWER TO THE PEOPLE
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
I know what lengths they go to to ensure it's more than just a Ford sticker on the part. Ford doesn't throw it's name on anything for a quick buck.
06 Turbo Terri AWD 6 sp in Neo with stuff i didnt even need, side steps,15.2 inch roof mounted DVD,Pioneer $tezza,Selby 30/18mm swaybars,debunged,100 cpsi Ballistic cat,Plazmaman under battery Cai injectors 14/lb boost,ZF tuned,Xtreme's magic. :
svo347 is offline   Reply With Quote Multi-Quote with this Post
