15-02-2006, 05:09 PM | #1 | ||
gday guys got my crow 2222519 and vernier gear fitted last week ive run it in for about 200kms but to be honest i cant really well any differance yer a bit but no were wat i expected now i gave it to my mechanic to do but im not sure if he "dialed it on" how do i do this
AU FAIRLAINE GHIA TICKFORD I6, KINGS SL/KYB ALL ROUND, RED BACK EXHAUST, G220 RIMS |
15-02-2006, 05:12 PM | #2 | ||
when i dialed mine in, the dude told me to take it for a driver for 2 hours, but it had to be under 2000rmps, so means no flogging it, by the time 1 hours gone u can start to feel it, so dosent matter if u go over now and then but really consntrate on keeping it under ;)
15-02-2006, 05:14 PM | #3 | ||
Last warning
you're refering to 'running it in' jo..
dialing it in involves ensuring the cam has the correct amount of lift at the right piston positioning. to dial in a cam, you need a dial indicator. the vernier gear is adjusted to ensure that the cam has the correct amount of lift @ TDC.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
15-02-2006, 05:19 PM | #4 | ||
That's not dialing it in, thats not even running it in.
Dialing it in, is when the cam is set to the grinders specifications or even advancing or retarding it to the tuners requirements, not just putting it dot to dot according to the manufacturers specs. This allows for any inaccuracies in the manufacture of timing gears etc. To dial it in would require cam specs showing lift @ .050" (for example), you'll need a degree wheel and a dial indicator to measure the .050"
Pit Lane Performance 20 Rosella St Frankston 03 9783 8122 Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
15-02-2006, 05:25 PM | #5 | ||
ow...crap....mix up :S well least i got a post
15-02-2006, 06:14 PM | #6 | ||
Last warning
dial in specs are usually lift @ TDC.
so you only need a dial indicator and to ensure the engine it as TDC.
15-02-2006, 09:38 PM | #7 | ||
so will this giv more power?
15-02-2006, 10:26 PM | #8 | |||
You will all of the above equipment.
