Hi All.
I'm in the process of dismantling my doors, and I've noticed a couple of door hinge pins missing. I thought that while the doors are apart, I might as well take them off & clean the hinge assemblies etc. I was wondering if anyone can give me any tips on removing the intact door hinges? I can't see any obvious starting point for getting them out. |
If you remove the centre pillar trims in a 4 door you will find the 13mm nuts that hold the hinge on and if you remove the front inner kick trim the nuts are also in there for the front door and up high behind the dash panel inside the door pillar you will find the top nuts
Jim |
Thanks Jim.
Hi, Can anybody help me with how to repair worn escort mk1 hinges. thanks
Over Thinker
Ekkie.... stop asking hard questions
![]() you may be able to find the hinge pin this ebayer has a lot of mark I doors so may have hinges ? http://www.ebay.com.au/itm/Ford-Mk1-...item3ce7aa5dfe the australian ford escort parts supplier we used to use closed up shop source of a new hinge would be the UK possibly
My car goes Brumm Brumm Last edited by dirty hands; 14-06-2015 at 11:08 AM. |
Or use 8mm bolts and nylocks like I have. makes future removal that much easier.
Unless the hinge itself has worn oval or oversized then its a bit harder but try running a 9mm ream through them and 9mm bolt. JP |
Hi, Thanks for your help. It is the holes that are slotted so guess I'll go for the 9mm bolt idea. Thanks again.
