Old 21-02-2006, 05:20 PM   #1
speed_freak
Default EA On Gas?
Hey guys my cousin just bout a 88 EA for his first car and i was having a look at it and it looks like it used to be hooked up to run LPG (im no mechanic but the injectors were different and the switch was still in the car) I was just wondering what do u think the costs would be to put a tank in if all the fittings are there and also will the car run fine.
Thanks
speed_freak is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2006, 07:59 PM   #2
need psi
slow & low EA Ghia
need psi's Avatar
depending on if all the stuff under bonnet (convertor, mixer, solenoid, gas line to boot) is there you shouldnt really have a problem, but your best bet is to take it to some one who knows about gas or a gas specialist and get them to check it out. leaglly in s.a unsure about other states you can only remove a gas tank but the gas tank can only be fitted or refitted by a licensed gas person. hope this helps.
Ehab
Ea Fairmont Ghia 1988
need psi is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2006, 08:02 PM   #3
speed_freak
kool thanks, im pretty sure all the fittings would still be there but yes ill take it to someone to check it all out
