Old 14-04-2016, 10:40 AM   #31
Squalo
Two Wheels Good
Squalo's Avatar
Default Re: Diesel engine life
Originally Posted by EDManual View Post
Yes 240k is terrible for what a diesel should traditionally be. Whats the point in paying extra for one in the first place, they were always meant to do double the km of a petrol (exept falcon 6's of course).
The 240k is not referring to when an engine blew up, it's the mileage on the vehicle the OP is looking at. My comment means that mileage isn't a big deal.
The only modern ones that may last are the v8 diesel landcruisers.
You might be surprised at how many of those V8s are having issues... the most robust diesels out there are the six cylinder Landcruisers and Patrols (specifically the TD42 for Patrol, the RD28 does cranks when the harmonic balancer fails).
2004 SX TX RWD Territory
2010 Mazda 3
1994 GQ DX TD42 Patrol
1969 Kombi
Squalo is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 10:54 AM   #32
mechanic
"Something like an NA HZ engine will last forever but what are they like to drive ?" SumoDog68
Absolute rubbish is what they are like to drive. I bought one after having Pajeros and a Hilux with a 253.
Sold it as soon as possible. They were basically the last gasp of Toyotas mining vehicles where they're flogged around mine sites as they have a fairly trouble free engine.
Mine had to have the pump and injectors replaced and a new clutch before it got to 100,000 klms.
Discontinued now, one of Toyotas smartest moves.
mechanic is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 11:37 AM   #33
waterskier
Currently have 262,000km on a 2013 auto 2.8ltr RG Colorado . Zero issues so far, just ordered a new timing belt from Holden for $300.00 that the manual states should be changed at 150k.
waterskier is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 06:21 PM   #34
383hq
Interesting comments
I did have a diesel ranger that was great - sold it at 100k k km(only just run in ?)
Fuel economy was the issue, or should I say tank size?
Chassis was nervous on dirt @120-130k km/h with heavy bull bar over the nose. Seemed inclined to want to try to swap ends...
Bought a diesel mondildo turbo for highway km's.
What dr terry says is bang on
Great highway fuel economy, but potential:
turbo failure/ wear out = big $, same for
diesel fuel pump failure = big $
injector replacement = big $
You get the idea, we trade (compromise) criteria
Recent factory service had $600 in "special" DCT trans oil on the mondildo, so
Economy has come at a cost - it's all a compromise....
(at 140k km now, wondering how good the engineers were with their 10 yr 200K design limits generally accepted nowadays :-)
On the plus side - mondeo seems to handle small kangaroo much better then big kangaroo v ranger with steel bull bar...
I believe newer more modern diesels have much better fuel economy = finer tolerances = wear out more quickly then the older landcruiser style 400,000km type donks.
I cannot confirm this with data - never kept them long enough - worried about the component costs (as others have indicated).
383hq is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 06:45 PM   #35
Mont5.0
Mont5.0's Avatar
I believe Direct injected diesels seem to have less issues than common rail, Look at Trucks.
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is online now   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 07:11 PM   #36
Pis-ton broke
Pis-ton broke's Avatar
i hear that the common rail diesel is sensitive to poorer quality diesel fuel, is this true? and this is why "special diesel" is for sale. and that its expensive to repair a stuffed fuel system.
Pis-ton broke is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 07:27 PM   #37
Itsme
Experienced Member
Itsme's Avatar
Never known any diesel engine to be cheap on repairs or parts whether old or new technology, something people should consider before purchasing.
Itsme is online now   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 07:32 PM   #38
From what I know, (I have only had a diesel for a month, however me wife has owned a direct injection turbo petrol for a couple of years ) direct injection places the injector into the cylinder head, and only injects fuel at the end of the compression stroke, iliminating the chance of detonation due to premature detonation caused by friction . On petrol models it can sometimes lead to buildup on the intake valves as there is no fuel (solvent) running over them, also in a turbo you can run higher compression as the fuel isn't injected until right before it's ignited
Old 14-04-2016, 07:46 PM   #39
Trump
bitch lasagne
Trump's Avatar
The build-up is cleaned by putting an upper engine cleaner through it.
Trump is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 07:56 PM   #40
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
You're now injecting fuel at 25,000PSI and upwards.
Which is why components are expensive, but mind you what car is cheap to fix anyway?
Direct injection petrol engines will also have relatively expensive fuel injection components too vs regular multipoint injection setups only running 45-60psi fuel pressure.
Ive got a TDCI Focus, its just clocked 100,000km and I've sent it down the 1/4 mile 6 times, had it tuned, bigger intercooler and at one stage was rocking a bigger turbo and sat through 90+ different tunes run up on the dyno, thrashed it over every single one of those 100,000km and it hasn't let me down yet, and does 5.7L/100km.
The only significant failure I've had was it killed a battery at 14,000km and blew the injector return line in 2012 which was a little clear plastic pipe.
Oh and I chopped out the OEM tyres at 25,000km.
People complain about servicing costs, the genuine oil filter is $20 and the oil is what any group IV synthetic costs for everything else.
Old 14-04-2016, 07:57 PM   #41
Haven't had any issues yet as the wifes car has only done 60k and my ranger has a tad under 50k on it, but I suspect the build up is due to the pcv
Old 14-04-2016, 08:03 PM   #42
sprintman1
Damn right it is on modern diesels. One shop I know here average 3 rebuilds a week at an average cost of $8,000 per rebuild purely due to the abysmal std of diesel fuel storage/shipping in Australia.
sprintman1 is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 10:31 PM   #43
SumoDog68
What sort of quarter does it run out of interest ?
SumoDog68 is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2016, 10:36 PM   #44
Franco Cozzo
Thailand Specials
I ran a 16.32 @ 80mph as my fastest time
I'm torque limited on my first 3 gears though, I don't have the full beans until 4th gear unfortunately.
Old 15-04-2016, 03:11 PM   #45
mik
mik's Avatar
true but it depends on the brand , years ago we used to talk/laugh about this stuff with big diesels ,
rebuild kit for a euro volvo engine only 5k ........... injector pump 20 k
american old style engine , 500 to 1000 bucks for a pump rebuild, rebuild kit 3 - 5 k .
and some of the old simple engines where rated for a million miles .
id be surprised to see too many of the little modern buzzy ones even making 400 k, happy to be proven wrong though.
Old 15-04-2016, 03:34 PM   #46
Itsme
Experienced Member
Itsme's Avatar
With proper servicing & maintenance I think 400 to 500K is quite achievable, depends on how they are treated by their owners.
