Old 26-06-2016, 05:23 PM   #1
mauricio
Default Is this an oil leak?
Gday all, I was doing a routine check under the bonnet and noticed what may be an oil leak from the inlet section of my engine. Wondering if this is a leak, or more a normal sweat, any help would be great.Thank you.
Mondeo 2009 TDCi MB.
mauricio is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2016, 12:36 AM   #2
cobrin
Challenge Accepted!
cobrin's Avatar
Default Re: Is this an oil leak?
That section is the Throttle Housing Anti-Shudder Valve. It's suppose to close when you shut down the engine reducing vibrations, mine seems to work, when I shut down it's instant and nothing felt/heard as you'd expect.
Take it off and clean it (as well as the MAP and Air inlet temp. sensors) then look at the EGR valve. There's an oil/air separator that may need looking into but don't quote me on that.
On the other hand if your charge air pipe is oily I hope it's not a failed seal or similar in your turbo. Lets just concentrate on it being a simple pollution gear issue and need a clean for now lol ;)
Old 27-06-2016, 01:23 AM   #3
cobrin
Challenge Accepted!
cobrin's Avatar
I was close Inlet Air Shut Off Throttle, controls the volume of air and EGR for the desired effects (read emissions) and ensures the engine doesn't run on after shut down.
Old 27-06-2016, 07:28 AM   #4
mauricio
Thank you, I'll have a closer look today.
