Old 28-11-2015, 10:38 PM   #1
ope126
ope126's Avatar
Default RE: ATE Ceramic Brake Pads & ATE Rotors
Hi All,
Just thought I would share some info if you are interested.
I have purchased the following ATE items direct from Germany to replace the original pads and rotors.
ATE SL.6 Dot 4 ISO Class 6 Brake Fluid
ATE Ceramic Brake Pads http://www.ate-brakes.com/www/ate_de...e_pads_en.html
(front) Article No. 13.0470-7228.2 / LD7228
(rear) Article No. 13.0470-2723.2 / LD2723
ATE Coated (High Carbon) Vented Rotors (300mm) http://www.ate-brakes.com/www/ate_de...heiben_en.html
(front) Article No. 24.0128-0250.1 / 428250
ATE Coated Solid Rotors (302mm)
(rear) Article No. 24.0111-0145.1 / 411145
For your info, here are the original part numbers also.
Original FoMoCo Part Numbers;
- (front) 300mm Rotor - 7G911125EA (Finis 1500159)
- (rear) 302mm Rotor - 6G912A315BB (Finis 1864280)
- (front) Brake Pad - BG912K021AA (Finis 1747043)
- (rear) Brake Pad - 6G912M008GF (Finis 1477803)
Please note the original pads and rotors are due for renewal and the original parts are more than adequate. The benefit of the ATE Ceramic Pads is lower brake dust. All other factors should remain the same!
I will report how they are once received and installed.
2016 (MY17) Ford Mondeo Titanium EcoBoost (Moondust Silver)...more power please!
ope126 is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2015, 01:24 PM   #2
rondeo
Default Re: ATE Ceramic Brake Pads & ATE Rotors
Thanks! How does cost compare with items from local Ford dealer?
Mine are coming up in 20000Km. Plenty of black dust.
Old 29-11-2015, 06:58 PM   #3
Binny
I'd be interested on the pricing as well.
I just had 90,000 service an apparently my rears need changing, fronts are fine. They want over $600 fitted for just the rears.
2016 Kuga Trend TDCi
Binny is offline   Reply With Quote Multi-Quote with this Post
Old 30-11-2015, 12:52 AM   #4
ope126
ope126's Avatar
These are just my findings, do your own research to see what works for you!!!
Ford Capped Price Brakes; http://www.ford.com.au/service/brakes
It would cost $654 including machining the rotors. However I was told that they could not be done on the Original Rotors and also the pads that are replaced (outside of warranty) are Motorcraft Pads and not the Original FoMoCo pads as listed / noted above.
So for that I was not interested.
I then looked at options and found that the Original Pads, Brake Booster and all Calipers and ancillaries on the Mondeo are ATE Germany.
I was considering TRW replacements, however I was keen on sticking with ATE.
The front rotors are High Carbon (as per Original front rotors) and the added bonus of getting Ceramic Pads both front and rear was a plus!
As for cost, it would have been cheaper getting the ATE Original Pads, however I chose the "Low Dust" option of Ceramic Pads and including the Rotors and Shipping it was about $250 cheaper than purchasing the FoMoCo parts as noted above. Yes I have to wait about a week, but I am not concerned...
Old 30-11-2015, 02:42 AM   #5
cobrin
Challenge Accepted!
cobrin's Avatar
Noice!!! (no not a typo lol)
I too have stock pads on the fronts, my rears needed changing and instead of machining the rotors I just sourced Protex equivalents (~$78ea) and used Bendix General CT. (DB1999) Totalling $224 to square the rear end away.
After 2-3 odd weeks there was stuff all dust on them very happy, but (and it's a big butt) soon after that they started to squeal when reversing (didn't matter at what speeds either) not only annoying but embarrasing. I've only noticed this month that it's stopped. Fitted nearly 12mths ago (man that goes quick). That sucked...now just have to work on the fronts when they are needed.
I get the feeling low dust pads are harder pads and need a little more pedal input, that and any kind of creeping movement from stationary they creak a bit noise wise. I'd like to hear your thoughts when you fit yours in that aspect.
Old 30-11-2015, 07:46 PM   #6
Binny
Are the rear rotors a simple swap? You don't need to press bearings in or anything like that? I notice Bendix have a "Euro" grade pad now so maybe that is an option?
Old 01-12-2015, 01:14 AM   #7
ope126
ope126's Avatar
The order is with DHL direct from Germany.
I have been tracking it and the order is now in Australia.
So hopefully I can get these installed soon!
Old 01-12-2015, 11:43 PM   #8
cobrin
Challenge Accepted!
cobrin's Avatar
Yeah the rotor is independent of the bearing/hub, it has a retainer screw but I pitched those as the RH/R was damaged (useless previous mechanic) straight swap.
Old 02-12-2015, 11:17 AM   #9
Deo
Deo's Avatar
So if I am reading you correctly, the full set of pads and discs for the car was about $400 shipped?
(that's all 4 corners plus some brake fluid thrown in too)
The price from Ford includes fitment doesn't it, but I guess you are doing it yourself, so free.
Sent from my GTi-9305 using bloody Tapatalk
_ __ __ __ __ __ __ __ _
_____________________
2010.11 Mondeo Titanium
MC Ink Blue Diesel Hatch
Deo is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2015, 01:29 PM   #10
rondeo
I wonder if you could provide details on how to obtain these. I need to do mine soon.
Old 02-12-2015, 01:47 PM   #11
rondeo
Quoted $918 for all rotors & pads Blacklocks Ford.
Old 02-12-2015, 01:49 PM   #12
rondeo
Parts only.
Old 02-12-2015, 05:59 PM   #13
ope126
ope126's Avatar
Here is a link; http://www.buycarparts.co.uk/
All parts sent from Berlin, GERMANY via DHL (as per the tracking details).
Old 02-12-2015, 06:00 PM   #14
ope126
ope126's Avatar
And yes, about a $250 saving on the above (including shipping) with Ceramic Pads, cheaper again if you get the standard ATE Pads.
Old 03-12-2015, 09:45 PM   #15
ope126
ope126's Avatar
All items arrived today!
Now to get them installed...
Old 04-12-2015, 10:09 AM   #16
rondeo
Thanks for the info, let's know how they go!
Old 09-12-2015, 07:11 PM   #17
ope126
ope126's Avatar
The brakes are being completed tomorrow...
Old 10-12-2015, 10:25 PM   #18
ope126
ope126's Avatar
Just to recap, I got the brakes installed today;
All went on without an issue.
Pedal feel and bite is top notch! (the parts removed were on their last legs)...
Will give the car a wash over the weekend and see how the brake dust goes!!!
Old 11-12-2015, 01:16 AM   #19
NZ XR6
Thanks for the post. I'm very happy with the standard brakes apart from the dust! I need new rear pads so might look at replacing them all with ceramic.
Old 11-12-2015, 10:58 AM   #20
Binny
I agree. The factory brakes are awesome. The best brakes on any car that I've owned. I'd be more than happy to pay the dealer for new OEM parts if they weren't so greedy.
By the looks of those ceramic pads they not only last longer themselves but don't put as much wear on the rotor either. Probably a worthwhile upgrade just themselves to reduce brake dust and prevent your OEM rotors from wearing out so fast.
Old 03-01-2016, 12:27 PM   #21
ope126
ope126's Avatar
3 weeks later and NO BRAKE DUST!!!
Old 27-02-2016, 12:59 PM   #22
ope126
ope126's Avatar
Another quick update.
There is no squeal or noises coming from the brakes.
The brake pedal is nice and solid, just like the OEM brakes.
And the brake dust is almost non-existent!
Rather than black dust it has a silver/gold dust that blends in with the wheels, so essentially making it appear like no dust at all!
Washing the wheels is easier too as it just sprays off without having to worry too much.
Overall, money well spent!
I hope this helps others!!!
Old 28-02-2016, 01:23 AM   #23
NZ XR6
Thanks for the update. I've bought a set of TRW ceramic pads for another car but haven't fitted them yet. I hope they're as good as the ATE!
Old 27-09-2016, 02:59 AM   #24
Deo
Deo's Avatar
Hi ope126,
I was hoping you might be able to give an update on how fast these were wearing down, but it seems you've traded in for a MD!?
Old 27-09-2016, 07:00 AM   #25
ope126
ope126's Avatar
Originally Posted by Deo View Post
Hi ope126,
Yeah in the MD now, but they were going strong.
Did close to 20,000km in around 6mths and they were faultless.
Brake dust was next to nothing!
Old 27-09-2016, 11:10 AM   #26
Deo
Deo's Avatar
Hmm I'm thinking of pulling the trigger using the same shop that you did.
I just can believe they are charging 108 uk POUNDS for any shipment to Oz!
Old 07-12-2016, 06:35 AM   #27
Deo
Deo's Avatar
Well I went ahead and bought these ATE components.
The front ones went on yesterday.
Everything fine so far. Any questions fire away.
Old 07-12-2016, 07:41 AM   #28
ope126
ope126's Avatar
Great to hear, let us know how they perform for you!
Old 12-12-2016, 07:20 PM   #29
383hq
ATE are OEM to porsche - they do good !
although I haven't used them on Mondeo, People will be well pleased with ATE - I was.
You won't complain about blue oval pricing once you start pricing OEM P-cars !
383hq is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2017, 05:35 PM   #30
Deo
Deo's Avatar
Thumbs up Re: ATE Ceramic Brake Pads & ATE Rotors
Just to update this thread after six months - no complaints.
I can't comment on the wear level, but the new brakes have been working well, no noise and the dust is invisible as advertised.
