28-02-2015, 12:23 AM | #451 | ||
Leftyos
Dave not sure what its like now but a few years back when i got mine sumitomo htrZ was one of the few around that were affordable $425 each in around 2006. I think the 80s corvettes ran 315s on a 17 inch wheel so there arent many cars that run this size tyre, maybe porsches in the 90s i dunno. Unless you are importing you may have trouble finding them. I priced big pirelli and michelins as well and they were getting up around 800-1000 back then and that wasn't even at 315 wide. If you do find some let us know what they are where you found them and $
Fat *** coupe lover |
10-05-2015, 12:25 PM | #452 | ||
Do most of you have drum of disc brake rear ends?
18-06-2015, 09:09 PM | #453 | ||
Hey there just happened to come across this helpful thread .I have a xa coupe with 15' x10 rear and 15'x8 front simmons wheels . i currently have a 295x50x15 toyo rear and 245x50x15 bf goodridge front with both work very well with no scrubbing . Im now at the stage of replacing the front 245x50x15 tyres as they are geeting a bit worn but as most know these tyres are now not available . What is my option now the 225x50x15 or 225x60x15 or 235x50x15 or 235x60x15 and are these options all still available ? thanks
19-06-2015, 07:05 AM | #454 | |||
COUPE WHORE
Rides 1974 Malvern Star Dragstar pushbike mods; bald back tyre, big sissy bar, speckled paint job and buckled front wheel |
02-09-2015, 11:22 PM | #455 | ||
Hi guys, would a 16 x 11 Simmon wheel with 145mm (5.7 inch) backspace fit on a coupe?
03-09-2015, 08:15 AM | #456 | ||
Moderator Ford Coupe Club
Not sure, probably but your measurements will need to be spot on. That backspace sounds like the inner edge of the rim will be very close to your rear leaf springs (assuming its a stock setup). The wheel arch lip may need a slight massage too. I think your biggest challenge for this rim is tyres. Have you identified which tyre you're planning to run?
Mitsubishi ASX Auto, White - Daily Commuter XC Fairmont Coupe, 351 4spd, Graphite Grey - The Antidote http://www.fordcoupeclub.org "If you don't know where you're going, any road will take you there" George Harrison 2001. |
03-09-2015, 02:27 PM | #457 | ||
Zero off set will probably get you over the line. I've seen a few coupe builds on AFF and one in particular ran 11x17 with zero off set and they fit nicley - fitted a 315 tyre
03-09-2015, 05:52 PM | #458 | ||
I don't have a coupe to put them on, just wanted to see if they were going to fit. If anyone in the Sydney area with a coupe is able to let me try them on the rear it would be greatly appreciated. Pete
22-02-2016, 12:08 AM | #459 | ||
Anyone here running 325/30R19's on the back of their coupe and 245/40R19's on the front?
Cheers Ryan
XA Falcon 500 Hardtop Build Thread |
29-02-2016, 01:27 AM | #460 | ||
Hi does anyone know of any suppliers that can supply Chrome 12 slotters 15 x 10 with 5 or 5.25 inch back space?
I would like original centres so that the small hubcaps can be fitted as well. Will also require a matching set of 15 x 8 slotters as well. I haven`t worked our the back space on the front yet but have 15 x 8 Pro Stars on my sedan and will just measure them. Back in the early 80`s I had a set made up by Bonnerup wheel works in Perth but they are no longer around. When I had them made in the 80`s I bought a set of Standard GS rims from an XY which had the lugs to attach the Hubcaps. Bonnerup wheel works cut out the centres, had them chromed and welded them onto chrome hoops at the Specified Back space. Amazingly the chrome wasn`t damaged bu the welding. I think I had to wait a while for the right Hoops to arrive, I want to have some more made the same way. I have worn my fingers out polishing alloy wheels. Any ideas of who can do this or can supply the wheels already made? |
29-02-2016, 03:45 PM | #461 | ||
Google is going to be your friend in this instance. Ajax motor wheels in melbourne( the only guys I knew ) that did this has shut down. no need to souce genuine ROH centres with the lugs as you can buy an insert that alowas you to fit the caps. Best of luck with your search
01-03-2016, 04:29 PM | #462 | |||
I can't remember the price offhand but I do recall it was reasonable. I supplied 14 inch wheels for the centres and he put them in 15 inch rims. Had them powdercoated afterwards and looked great. |
21-04-2016, 11:09 PM | #463 | ||
Okay I have sourced some tyres for my Performance Industries Challengers.
I can get Hancock 225x50x15 tyres to suit 15x8 front wheels @ $150 each. And for the rear 15x10 wheels a Sumatomo 265x60x15 tyres @ $260 each. Anyone have any experience with these 2 tyres? Pricing sounds ok? If I wanted the same brand of tyre front & rear this particular supplier can only offer Maxis brand in these sizes & the rears where about $350 each. Any thoughts?
http://www.fordforums.com.au/showthread.php?t=96863 |
25-04-2016, 08:14 AM | #464 | ||
Could you go 295 50 15.
Various brands from 170 on eBay with Hankooks starting from 195 for the bigger tyre.
BLACK XB COUPE 351C 5Speed Doug Nash Cleveland goodness wrapped in a FORD shell |
18-05-2016, 12:51 AM | #465 | ||
Tyres purchased & wheels fitted.....happy with them, will probably black out the white lettering.....I'm sure some wont like my Globe stickered caps but oh well
[/URL] [/URL] [/URL]
5 users like this post: |
03-08-2016, 02:08 PM | #467 | ||
This is a post from my build thread, The new boots for the Coupe turned up, I’ve gone for 245/45ZR17 up front & 315/35ZR17 for the rears went with Nitto NT555's in the end & no, no tire in 315/35ZR17 is "cheap" but I didn't think these where too outrageous in the end
A quick test fit shows that Ford really did get the rear wheel wells right on this car, the rear suspension leaf springs are stock for now & the Guards are not rolled. As you see 315 fits easy I know that there is no weight in the rear right now but there is plenty of clearance to play with, 20mm from the widest point of the sidewall to the spring (won’t matter to me as I’m removing the springs anyway) The tire is still within the guard edge too & there will be no need to roll them if I don’t want to (might do it before I paint the car anyway in case I ever go fatter) I reckon that 335’s would fit with no mods, they’d scrub slightly but they’d fit & I reckon that 345 would be possible with rolled guards
4.2 Supercharged V8 RangeRover Sport - Daily driver 1975 XB Fairmont GS Coupe - Ford Weekend Toy 1975 XB Falcon 500 Coupe - Undecided Project 1972 Dodge Challenger R/T - Mopar Weekend Toy 1969 GTO - Pontiac Weekend Toy |
21-08-2016, 11:20 PM | #468 | |||
24-08-2016, 12:18 PM | #469 | ||
I assume you just mean the rears?, they are 17x10.5" with a 6" backspace
08-11-2016, 09:46 PM | #470 | ||
Hey Fellas, I want to get some of this 15x10 action for the back of my XA hardtop. Is there any chance of mickey thomson 28 or 29x12.5 15s fitting a standard length diff without guard mods? Any improvements if you go 10.5 tyres instead of 12.5s?
Im struggling a bit trying to decide between 15x10 magnums/jellybeans and convo pros Captain Risky |
10-11-2016, 09:53 AM | #471 | |||
Big Member
The Scarlet Fairlane: 94 5.Slow Litre NC II Fairlane 488800kms & Climbing Rollin' on genuine ELGT wheels. K&N Filter /////Alpine Sound. EBGT Momo Woodgrain Steering Wheel The Scarlet Fairlane Build Thread Project "White Knight" 93 ED XR6 ROH Alloys Momo wheel Cruise Sunroof Premo Sound Manual HO Goodies PWK Build Thread 1990 Yamaha FZR 250: 59000ks & climbing. New fairing, old tank, my angry mosquito in a coffee tin! 14.977 1/4mile. |
14-11-2016, 08:47 AM | #472 | ||
Ha ha, I assume you refer to the xb four door in the tv insurance ads? It was out of commission following the recent speedway debacle however it will return bigger, more wonderful and more powerful than ever! I have recently concocted a intake system of 8x 350 holley carburettors and 2x superchargers on an ingenious cross ram manifold of my own design ;), with which I will attempt to jump the main crocodile pool at Australia Zoo. While still negotiation the fine minuta with the Irwin family at the present, and working hard to tune out the massive holley dead spot, I am confident with the tremendous power from my new setup I will not fail!
On a more serious note I scored a pair of 15x10 sampsons in 5" backspace on the weekend, bought brand new by the seller 30 something yrs ago, never fitted to a car, in amazing condition they dont even need polishing! Ive read this thread start to finish several time, I noticed old mate with these rims on his cobra has 5 1/4 backspace. Are my rims fine to use as is or should I machine the extra 1/4 in from them before the tyres get fitted? Captain Risky eagerley awaits a reply.... Last edited by Captain Risky; 14-11-2016 at 09:04 AM. |
18-11-2016, 10:39 PM | #473 | ||
Awesome buying there, just love old Skool Sampson/Magnums. If I were you I'd fit up the tyres then try the wheels on the car. The tyres (295 I assume) will have sidewall bulge and some sidewall flex on cornering so you want to make sure you have enough clearance to the rear springs.
There would be nothing worse than taking material off the hub face of those wheels only to find you have tyre rub against the springs. Can't put that material back on!!! Convo Pro's??? Done to death!!!
19-11-2016, 01:56 AM | #474 | ||
Thanks Bearman, i think they look awesome too. Now to find a pair of matching 15x8s or even 14s. Was hoping to fit some of those Mickey Thompson sportsman or goodyear race tyres, pretty close to a 295 for width though, Captain Risky |
15-12-2016, 11:49 PM | #475 | ||||
Leftyos
24-03-2017, 11:54 AM | #476 | |||
100% snafu
I have 14" Hotwires which I presume are 8" (8JJ x14 stamped in the centre) currently wearing 215/65 rubber. Might stick with that size on the front as they already rub in extreme cases, or full lock, but maybe time to fill some of that space in the rear. Anybody recommend a tyre joint preferably SE burbs? |
23-06-2017, 10:16 PM | #477 | ||
RPO 77
So looking to obtain the stance of the 1974 Goss/Bartlett XA beast.
Looks like the rims are 15" x 10" challengers front and rear - but the tyres i am struggling to make out - maybe a wider 40 series on the rear and slightly skinnier 50 series on the front? Does anyone have any info as to the setup/spec on this vehicle - STD width diff? Suspension?
Q: If you have tried to sell it three times now and it is still not sold, do you think it might be over-priced? A: It is over priced - just like all the other falcon coupes for sale!! |
