Hi, pleased to report the trusty MC Mondy (233K) was serviced by my mechanic onsite at home yesterday and after 10,000 clicks it had not used any replaceable amount of engine oil. Only the very small amount from the main engine seal. Only noticeable on the inside of the bottom plate. None on the ground.
Anyway thus the title of this thread. SOD-1 Plus is an oil additive. After being asked to Google as much info as possible it was beginning to sound a feasible additive albeit not so cheap and damn hard to find. Found and spoke to Japanese chap who is their Australian agent and he happens to be only a couple of suburbs away from me. Please let me know prices and where available you have seen it. I will post my findings later. For now I can say it comes in 400mm sample bottles, 1 litre and 4 litre containers. Agent is currently out of 1ltr bottles. Do have a read here (Videos also) and elsewhere on their site and post your thoughts... http://sod1plus.com/what-is-sod-1/ Thx
Cheers Pete Melbourne 2010 Ford Mondeo Zetec TDCi Diesel ![]() Colour: Frozen White ![]() |
Never heard of it, that said - I am sure it is a good product.
For me, you just cant go past the range of Liqui Moly; http://www.liqui-moly.com.au/products/oil-additives/ Easily available at retailers such as autObarn and Supercheap!
2016 (MY17) Ford Mondeo Titanium EcoBoost (Moondust Silver)...more power please! |
#3 | |||
As you say this product claims what I require in rejuvenating seals at a fraction of the Sod-1 price... http://www.liqui-moly.com.au/product...resealer-2782/ Interesting on the claimed rubber swelling... http://sod1plus.com/benefits-data/ LOL Sod it as it could be worth it. ![]()
#4 | |||
Mine is developing quite a leak that I initially thought might be the rear main. Last service I did a little investigating and the oil seems to be coming from up near the turbo somewhere and running down to the join between transmission and engine. I couldn't pin point it lying on my back under the car so I will have to borrow a hoist next service to have a better look. Its getting to the stage that I can occasionally smell hot oil as is drips onto the exhaust.
2012 MC Mondeo LX TDCi Wagon - Highway Hack 392K km and counting - Now gone 😢 2008 Peugeot 308 HDi - Highway Hack II 2008 Citroen C4 HDi - Highway Hack III 2010 Peugeot 308 HDi SW - Shaggin Wagon II 2016 VDJ200R Landcruiser GX Wagon - TTD V8 Power ![]() 2017 Toyota RAV4 GX Wagon - Shopping trolley - Gone 2022 Volvo XC40 T4 Inscription - Shopping trolley II 2002 BMW R1150GS |
#5 | |||
Challenge Accepted!
Currently at 197K so I've got some work coming up.
Undecided replacement... [SOLD] -2009 MB Mondeo Zetec TDCI- [SOLD] |
#6 | |||
I was hoping it was oil spillage from the filter change but its coming from the wrong side of the engine. I rolled over 178K last night so will be due for 180K in a couple of weeks. Ill give it a clean down a couple of days before then try to get in and find it whilst doing the transmission service. Hopefully something easy to fix.
#7 | |||
I found a slight oil leak from the rear main when I did the first oil after the car was out of warranty. There was a small patch of oil on the cover under the engine.
It doesn't seem to get any worse, so I just clean it up at each oil change. Sent from my SM-G9208 using Tapatalk
#9 | |||
Does the Mondey MC come up with a digital message warning of low oil pressure? Certainly loves to remind me the windscreen washer water is low. LOL Would need hot water(Only joking) just now as it is a solid sheet of ice. Presently(8.30am) -0.1c and was -2c at 5am. ![]()
Ditto. There is very slight weeping on our LX and zetec, but no drops, just wipe off at oil changes.
Message indicator goes amber on low oil according to manual, which is as clear as mud to me. The LX also has an oil leak at the diesel fuel pump, I changed the gasket but it still leaks. The aluminium casting is in two parts. I think the join is the root cause. You can check this by reaching from the front and feeling under the fuel pump inlet metering valve. Last edited by rondeo; 02-07-2017 at 09:18 AM. |
#11 | |||
Heated Washer Jets on our cars too!
#13 | |||
#14 | ||
Diesel fuel pump is driven directly by the exhaust camshaft so it's to the rear on passenger side.
On mine there is a very slow drip from underside of the fuel inlet metering valve. Inlet metering valve is in the small cylindrical casing just below and to the rear of the pump body. Easy to eliminate as origin - It and oil leak can be seen from under the bonnet. (A narrow beam 3 watt led torch works for me) Regarding the original post: If engine oils could be improved that easily why wouldn't oil manufacturers do the same? |
#15 | |||
Found this info on another additive and it to is not cheap and also comes with a lot of convincing hype. Its pricing is similar to SOD-1 Plus http://liquidintelligence.com.au/pro...-seal-expander SOD-1 Plus per 1 Litre is $110 Anyway at this stage I won't bother and will wait for Oz Lotto to upgrade my wheels. So SOD it for now. ![]()
