Old 24-11-2017, 11:03 AM   #1
DieselFan
Default Going into limp mode on highway
Hi.
My 2011 diesel is going into limp mode after about 2 to 3 hours on the highway.
I got a cheap scan tool off eBay and the error is p2263.
In the past I was advised to change an $800 dpf injectior in the exhaust.
That hasn't helped.
DieselFan is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2017, 11:44 AM   #2
rondeo
Default Re: Going into limp mode on highway
My 2011 diesel also had limp mode and p2263.
Replacing the boost solenoid fixed it.
Same thing happened with our other 2011 diesel, same fix.
In both cases the valve was mooing on switch off,
which may or may not be a sign of impending failure.
In any case, the new valves are quiet.
Old 24-11-2017, 07:54 PM   #3
cobrin
Challenge Accepted!
cobrin's Avatar
two common areas for that fault:
3. Boost actuator (as said above)
2. EGR valve stuck open
also a split turbo hose is said to give a similar code.Does it judder around 1800rpm? (pretty sooty)
Undecided replacement...
