Old 24-03-2006, 06:19 PM   #1
graeme1964
Default HELP oil pan "sump" problems
how the hell do you get the oil pan off a 3.9L ea without removing the motor from the car?
graeme1964 is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2006, 06:36 PM   #2
XRated
Shoot.
XRated's Avatar
No can do.
Unless you drop the K-Frame
20V Turbo
XRated is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2006, 06:39 PM   #3
xd5.8l
xd5.8l's Avatar
ИИИИ job need to drop the whole front subframe with struts and have a cross bar holding the motor up. very messy.
xd5.8l is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2006, 06:42 PM   #4
sphell
sphell's Avatar
Pull the motor out, its the easiest way.....seriously.
Worst design ever.
sphell is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2006, 11:04 AM   #5
naughtyfalcon
a above
2000 AU Wagon
naughtyfalcon is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2006, 12:12 PM   #6
henz79
Do you really need to remove the sump.... If you want to remove the sump casget because of an oil leak maybe the BOLTS are loose just retighten it.......It happen to mine to....... JUST A THOUGHT........
henz79 is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2006, 12:30 PM   #7
naughtyfalcon
while retightening the bolts can provide a temparary stop eventualy the gasket will need to be replaced,,,taking the engine out is the easiest but not cheapest,,unless you can do it yourself way to do it..
or get another engine,,thats what i'm doing,,im replaceing the 3.9 with a 4l form an eb,,i'll be getting all the gasket replaced before it goes in,,,
2000 AU Wagon
Old 25-03-2006, 01:07 PM   #8
MustangNicko
MustangNicko's Avatar
I got the engine pulled when mine was done. Had to do an oil pump/pickup. Did the rest of the main seals while i was at it.. Timing cover, rear main, balancer, sump all the crap.
MustangNicko is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2006, 01:27 PM   #9
LUXO_8
windsor user
thats the way to do it, preventitive maintainance.
as mentioned, whilst the engines out, replace everything thats dispensible, right down to welch plugs, hoses, etc... they may not be gone yet, but chances are they're not far away
Old 25-03-2006, 01:30 PM   #10
EFFalcon
Last warning
EFFalcon's Avatar
dropping kframe is easier then pulling engine out.
i've done my car before, still need an engine crane though.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 25-03-2006, 11:19 PM   #11
graeme1964
Unhappy This design sucks!
thanks for the advice guys, got ahold of a engine lifter today and I'm pulling the motor out tomorrow. What a stupid design! I'll let you know how it goes.
