Old 29-03-2006, 06:27 PM   #1
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
Default Valve springs
quick question...... can the valve springs in my ef 6 be changed without taking the head off?
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw)
2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned)
Mr_4.0 is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2006, 06:37 PM   #2
Gunns
Gunns's Avatar
Yes!.........................
Gunns is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2006, 06:40 PM   #3
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
thats what i thought, and this dumbass mechanic told me he would have to take my head off!
Old 29-03-2006, 06:53 PM   #4
Gunns
Gunns's Avatar
Nah just need the tool to do it.
Old 29-03-2006, 07:01 PM   #5
LUXO_8
windsor user
ive seen it done by filling the cylender with air (as in with a fitting in the spark plug hole using a compressor)so the valve doesnt drop down.....if you cant get use of the propper tool for it
Old 29-03-2006, 07:04 PM   #6
EFFalcon
Last warning
EFFalcon's Avatar
proper tool only compresses the valve spring so you can get it off.
you still need to fill the cylinders with something to prevent the valve from falling into the cylinder.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 29-03-2006, 07:07 PM   #7
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
thanks guys
Old 29-03-2006, 07:20 PM   #8
INJECTED_250
Custom user title
INJECTED_250's Avatar
if u dont have a compressor, u can feed rope down the spark plug hole like a fiar bit of it, and gently wind the motor untill it stops , This is pushing the piston up against the rope and the rope against the valves holding them tight. Then u can use the tool to compress the valve springs and remove the collets..
Make sure u have the rocker gear of but leave the cam and gear on. This way is only really usefull if u dont have an air compressor as it takes ages
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2006, 07:44 PM   #9
EB Pete
EB Pete's Avatar
Location: Under the bonnet, trying to keep as clean as above!
using a rope would be a bit dodgy wouldn't it? you get dirt and tiny little strands in there.
EB Pete is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2006, 10:25 PM   #10
hornet
hornet's Avatar
I did all 12 of mine using the compressed air method. Worked a treat. I was ИИИИting bricks the nights before and had nightmares that I dropped a valve :(
5 Speed EL Futura
140rwkw last dyno
hornet is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2006, 09:16 AM   #11
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
if i payed sum1 to do this for me, how much would i be up for in labour?
Old 31-03-2006, 11:38 AM   #12
heckaz performance
$100 - $150 for labour I reckon, tops. You may even get it done cheaper.
heckaz performance is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2006, 12:16 PM   #13
Felony
Wherever u go there u r
Im about to get the same thing done, im debating getting someone to fit the springs with the head on the car or just stop being a ИИИИИ and taking the head off and working that too...
i dont know how many more beatings from the missus i can take spending all the wedding money :P
Felony is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2006, 04:03 PM   #14
steven95falc
the tool is easly made with an old spark plug and bronze a bit of tube on to it and an air fitting the actual spring compressor can be bought at any good tool shop bearing wholesalers ect.
steven95falc is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2006, 07:27 PM   #15
Walkinshaw
Two > One
Walkinshaw's Avatar
why not just push the piston to TDC. Valve can only fall 5mmish
Walkinshaw is offline   Reply With Quote Multi-Quote with this Post
