Old 29-05-2019, 01:52 PM   #31
Nikked
Oo\===/oO
Nikked's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Long time member, loves Fords, sensible contributor and does some good and interesting posts.
Default Re: New Larger Mustang Platform
Originally Posted by cheap View Post
Smaller footprint and 400kg lighter would be the way forward, if it becomes bigger then I fear Ford have learnt nothing from the early 70’s when mustangs became bloated blimps and any notional sportiness was lost.
In the 70's the mustang actually was smaller.
The 2nd Gen mustangs were built on the smaller pinto platform than the Falcon based 1st gen. Result was a mustang half a meter shorter and 1/4 tonne lighter.
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2019, 01:57 PM   #32
Bossxr8
Peter Car
Bossxr8's Avatar
Originally Posted by SCUD View Post
Well I know that I'd have a Dodge Challenger... so there's that..
Yeah, but it's a 2 tonne land yacht based on a decades old Merc platform that should have been replaced long ago, and would have been if FCA had any money to do it.
Surprisingly it still sells pretty well though.
Old 29-05-2019, 01:58 PM   #33
Bossxr8
Peter Car
Bossxr8's Avatar
Probably referring to the late 60's, early to mid 70's models that got a lot bigger than the original.
Old 29-05-2019, 03:43 PM   #34
Poetic Justice
NOT A TOYOTA :/
Poetic Justice's Avatar
Originally Posted by chevypower View Post
No way, the Mustang is a much better car to drive.
I didn't say it was better or worse.
06 LandbargeCruiser Sahara
Managed to remain in the v8 fraternity
Poetic Justice is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2019, 04:25 PM   #35
Nu66et
Those numbers are based on the final first gen models.
1964: 4613mm, 1109kg base
1967: 4663mm, 1251kg
1969: 4762mm, 1416kg
1971: 4813mm, 1615kg
1973: 4445mm, 1233kg.
Whether it was to accommodate the bigger engines or for other reasons, the Mustang was growing quickly and sharing less and less with it's Falcon base with each update.
Nu66et is offline   Reply With Quote Multi-Quote with this Post
