Old 01-04-2006, 09:47 AM   #1
JUZXR8
Hmmmmm
JUZXR8's Avatar
Default Territory Mags
hey guys,
just got a set of ford territtoryt mags for the EA yesterday....$300 with new rubber! They look sweet as, but ive got a lil problem, The two backs go on fine, but when i was putting on the fronts they go on but they hit the suspension arms the sit in the wheel arch.....a mate suggested using spacers but that idea doesnt really appeal to me. The wheels are 17's, but they dont have low profiles so i was thinking is should try and put some on to c if it helps. I was hoping that there might be a cheaper option tho?
JUZXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2006, 10:25 AM   #2
Olympus
Rocket Fuel Anyone?
Olympus's Avatar
Interesting, got any pics ?
Olympus is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2006, 11:48 AM   #3
John_LS1
you will need 30mm adapters, im pretty sure there the same offset as AU/BA rims.
Old 01-04-2006, 12:50 PM   #4
EDXR6T
how do he rear's fit the pre AU offset?
i was led believe that thy wouldent fit EA-EL's because of the offset
i was thinking of getting two for the rear and paint them gloss black;D
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2006, 12:53 PM   #5
FRDXR6
FRDXR6's Avatar
There the same offset as AU/BA so you will need spacers or hub adaptors!
Also im fairly sure the back ones will fit but not the fronts, as i have seen e-series running AU stockies...
FRDXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2006, 12:57 PM   #6
XR Martin
XR Martin's Avatar
Rears will fit but sit in an inch.
You need bolt on adaptors, 4x of them, not just 2
2004 BA wagon RTV project.
Old 01-04-2006, 04:42 PM   #7
JUZXR8
Hmmmmm
JUZXR8's Avatar
yeah got it sorted, put 12/16 spacers on the front with a set of low proflies and it all bolts up nicely! ill get pics up soon
EDIT: heres a pic
Old 02-04-2006, 12:51 AM   #8
Olympus
Rocket Fuel Anyone?
Olympus's Avatar
Looks pretty good actually, very original.
Old 02-04-2006, 08:07 AM   #9
JUZXR8
Hmmmmm
JUZXR8's Avatar
yeah for the money i paid i really impressed, im goin hunting for centre caps now
Old 02-04-2006, 08:38 AM   #10
LUXO_8
windsor user
EDIT: heres a pic
you need to chuck those the spacers away and get the propper ADAPTERS....which bolt to the hub and have their own seperate studs for the wheels...
what you're doing with using regular shiitty spacers, is putting alll the weright of the rim and car on the wheel studs, not on the center spiggot of the hub.. this will cause your wheel studs to break......and you can tell what hte end result of that will be....
