Old 19-11-2019, 04:39 PM   #1
mmhmm
mmhmm's Avatar
Default Engine and Fuel Additives - what do you use
Hey Guys
As the title goes. What do you use in your motors as an additive or fuel additive/cleaner.
I recently used the liqui moly fuel injector cleaner system and found it good. Engine additives i used the Green nulon additive for high mileage cars and stopped the ticking in my old vehicle.
what do you guys use or swear by that can work for our motors / performance and increase the life wear of the engines
want to see what else is good out there!
mmhmm is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2019, 03:50 AM   #2
Specialst
Question Everything...
Default Re: Engine and Fuel Additives - what do you use
https://www.fordforums.com.au/showthread.php?t=11471872
RUN
Current:
*2013 FG2 G6E-Turbo Ego
Worked by Rob at Monsta Torque
Lots of work….503.1RwKw @ 895Nm….
Out in the ether somewhere:
* 2009 FPV 5th Aniv GT Lightning Strike - Sold
Stock - 315 Kw
* 2008 FG1 XR6 Turbo Silhouette- Gone
Tweaked - 278 RwKw
Specialst is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2019, 07:17 AM   #3
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Every 10,000km I toss in an injector cleaner.
Just before every oil change I add an oil flush before I get to the mechanic.
I have another car that sits for quite a while between runs - before I use it I baby it to the servo and fill it with 98 plus an octane boost because whatever is in the tank would have sat for several months.
Don't care for brands - I buy whatever is on special at the time and often stockpile several bottles when I can get a good deal.
___________________________
Old 23-11-2019, 07:50 AM   #4
XR Martin
XR Martin's Avatar
Injector cleaner is just liquid hydrocarbons, just get the one with the highest amount.
2004 BA wagon RTV project.
Old 23-11-2019, 10:12 AM   #5
Itsme
Itsme's Avatar
Depending on what you using your additive for I use Fuel Doctor, good product for petrol or diesel engines.
Old 23-11-2019, 10:14 AM   #6
71cop
None.
71cop is offline   Reply With Quote Multi-Quote with this Post
