Old 08-12-2019, 09:22 PM   #1
Falcon_Crazy
PX3 WildTrak & RTV
Falcon_Crazy's Avatar
Default Ba falcon wont start
So nephew stuck in outback nt
Only light flsshing is the engine imolisation flsshing
Swapping batteries didnt help
Any thoughts people..im meant to be meeting him in to drive home next week. Any thoughts ?
[COLOR=Red]I really am Falcon Crazy[/COLOR
NextGen Ranger Wildtrak with loads of goodies
Sold PX3 Ranger Wildtrak 2.0Ltr UHF, Long Range Tank, Bullbar, Snorkel - 104,000km
BA Falcon RTV - Project Ute 265,000km
Sold PXII Ranger XLT Cool White. 105,000
Sold PX Ranger XLT in cool white, 151,700km on clock.
Sold FGII XR6T Ute LTD Edition in Kinetic.
Sold FG XR6 Ute
Sold BA Falcon RTV. 251,300km.Was a great mate for last 7 years
Sold AUII XLS Ute
Sold '85 XF & Crashed 84 XF
Falcon_Crazy is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2019, 09:28 PM   #2
Default Re: Ba falcon wont start
Has it been interfered with - any attempted thefts, has the ignition lock fallen apart, are you using a genuine key or a clone?
Old 08-12-2019, 09:32 PM   #3
Falcon_Crazy
PX3 WildTrak & RTV
Nah hes been so remote no chnace...changes battery thats about it
Sold FG XR6 Ute
Sold AUII XLS Ute
Old 08-12-2019, 09:41 PM   #4
Check all the plugs are seated fully - especially those at the bottom of the column and in the kick panels. Lock the car with bonnet up, disconnect the battery and wait a while. Reconnect, unlock the car and try again.
Old 08-12-2019, 09:43 PM   #5
11ford11
check ignition switch as mentioned
check interior light fuse
check ignition fuse under bonnet fuse box
does it have instrument warning lights (reds)-does it crank at all
try poring hot water on ecu wriggle connections at ecu
does fuel pump prime when key turned on (possible fault with engine relay and or fuel relay)
is it in park
does it have a fuel cut switch at top edge of left hand kick panel
try to supply more detail - is it cranking and not firing -6 or 8- sedan _ did it over heat. etc
Old 08-12-2019, 10:10 PM   #6
Falcon_Crazy
PX3 WildTrak & RTV
Thanks guys. I haven’t had BA for years.
It’s. 6 auto. Sweet ride when she goes. He’s on bad internet so sending all feedback. I will be there next week. Hope it’s going by then or long trip home via DARWIN
Sold FG XR6 Ute
Sold AUII XLS Ute
Old 08-12-2019, 10:23 PM   #7
Falcon_Crazy
PX3 WildTrak & RTV
So no crank. Just the odo comes up and yellow hand symbol on dash. No injector noise. Asked him to do some of above. He’s looking for other key. His dad May have it so I need to get that to him
Sold FG XR6 Ute
Sold AUII XLS Ute
Old 09-12-2019, 12:02 AM   #8
Check:
a) He hasn't added a magnet or an electronic device to the key ring?
b) He not next to something transmitting a radio signal or electrical field or a magnetic field?
c) He doesn't have the other vehicle key fob or a fob from another vehicle somewhere close without realising it (you cannot have two active fobs within the Smartshield antenna field at the same time)? I have seen people put on a coat etc they have not worn for a while and found they had an active "lost" key fob in one of its pockets.
Does the light ring around the key barrel go on? Is the remote fob battery good (put a new one in anyway)? Has he check all fuses? Especially BEM fuse.
In any event, what were the sequence of events leading up to the no start between when the vehicle last ran and he tried to start it again.
aussiblue is online now   Reply With Quote Multi-Quote with this Post
Old 09-12-2019, 12:05 AM   #9
arronm
BA/F6 BF/F6 SSV/R TTG
arronm's Avatar
If key was dead car would start then stop after a short period.
Does the starter relay click?? Does the starter motor solenoid click.
BA BF FPV starter button repairs. PM me.
Nizpro equipped and Tuned by the BEST in the west
Xtreme Ford Tuning
479RwKw Fuel limited, more pumps and power too come.
F6#0507 & #0639 Pro racer and Tech expert
NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below.
https://youtu.be/oa4IfguGQ-A
arronm is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2019, 06:15 AM   #10
Falcon_Crazy
PX3 WildTrak & RTV
Thanks all. Car don’t kick over at all. Told him to give starter motor a hit with hammer.
Car started OkY and he drove it 2km to the pub. Went to get back in and go - dead. He changed the battery recently but that’s it.
He only has key. There is no remote fob. And apparently spare key is at my joint somewhere.
He has only ‘Coon in town and it’s very much an RF free zone at Larrimah.
I’ve asked to listen for fuel pump priming. They left battery off it for 20 mins. He will head back to it first light.
Thanks guys - we need to try anything before a $$ tow to Katherine.
Sold FG XR6 Ute
Sold AUII XLS Ute
Old 09-12-2019, 07:02 AM   #11
The Yeti
The Yeti's Avatar
If it started with started “encoragment” I recon that’s your problem
Tap it and off you go until it’s had it’s last tap
Pariahs C.C.
What could possibly go wrong
I post images with postimg.cc (so I don’t forget)
The Yeti is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2019, 09:51 AM   #12
How has this shaped up?
Old 01-04-2025, 12:27 PM   #13
joey_hunter
I've got a 2006 bf xr6t starts sometimes. When I turn the key over I hear the starter motor. When I turn the key off it has a backfire even with a jump-start. Still finding it hard to start. Sometimes if I hold down. The start for 5 seconds or more it'll start
joey_hunter is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2025, 12:29 PM   #14
joey_hunter
