View Poll Results: What Tyre Pressure Do You Run | |||
32 p.s.i. |
13 | 6.07% |
34 p.s.i. |
8 | 3.74% |
36 p.s.i. |
36 | 16.82% |
38 p.s.i. |
59 | 27.57% |
40 p.s.i. |
73 | 34.11% |
42 p.s.i. |
17 | 7.94% |
44 p.s.i. |
7 | 3.27% |
Something else, please comment in the thread |
1 | 0.47% |
Voters: 214. You may not vote on this poll |
#61 | ||
HELL YES
44 psi on 20's using a decent tyre guage. Those servos can vary by 4 psi either way.
Max pressure rating on my tyres are 51psi FYI when I was doing track days I would drop to 36-38psi as I would see the pressure raise by 6-8psi depending on the track. Tyre wear has been good allround.
2016 Focus RS Nitrous Blue Ordered 3/11/2015 and delivered 22/6/2016 2019 Ssangyong Rexton fourby (the daily driver, tow pig & snowmobile) Last edited by Cheech; 30-09-2013 at 11:40 AM. |
#62 | ||
40 PSI 19's All round
BF F6 Typhoon: Fully opt. Standard except for filter and turbo line |
#63 | |||
I'll take them up to 36 and see how it feels. Thanks for the tip Cheers |
#64 | |||
Bathed In A Yellow Glow
Once I thought like you, staggered pressures front and rear as per the recommendations for the car and or what ever my mates would say was a good thing. After damaging 4 rims (2 at one time) over a 12 month period my local tyre people told me to back the pressures off to let the tyres give a bit when they took a hard hit instead of them being so firm they channelled the energy into the rim buckling them. I was running 42 and they recommended 38. 4 years have now passed since that advice and I haven’t damaged a rim. I still travel the same rough roads and some may say it just 4 years of good luck and they could be right but I like to think it's simply good advice. I run a number of different suspension options from stock to lowered spring packages and coilovers. Some of the tyre/rim combos I’m currently running at 38psi are: 20x8.5 255/35/20 20x10 295/30/20 20x8.5 245/30/20 20x10 285/25/20 18x7.5 215/40/18 18x8.5 245/35/18 15x7 215/60/15 15x7 215/60/15 My tyre wear is even, the ride comfort is fair and the handling, well honestly I don’t push my cars hard enough to pick the difference from 38 or 42. |
#65 | |||
![]() ![]() Join Date: Jun 2006
I have been maintaining mine at 38 psi front and rear when cold (having my own inflator/gauge at home). The original 18" 245mm width Dunlops on my XR50 at 42,000kms have very even wear across the tread width with about 4 mms of tread depth remaining, on all 4 tyres. My previous Ghia 17" 225 and 235mm width tyres also showed even wear across the treads at this pressure. Too low a pressure you get more wear on the shoulders than the middle, too high pressure you get more wear in the middle. On track days pressures are increased to 45psi or so as there are higher loads on the tyre when cornering etc than when driving normally, so gives more grip under those conditions. Last edited by Silver Ghia; 30-09-2013 at 03:27 PM. |
#66 | |||
![]() Join Date: Mar 2007
Craig H
Labels are for jars, not for people. Life is a journey, not a destination. ~~~~~~~~~~~~~~ Daily: 2013 FGII EcoLPi in Winter White Play: 2015 FG X XR8 in Emperor Show' N Shine thread Gone, but not forgotten: 2015 SZII petrol Titanium Territory in Emperor |
#67 | ||
I would assume most of the replies here are talking about cold tyre pressures as this is the way most of us would have been taught to check them.
#68 | ||
running 245/35/19 Goodyear Eagle F1 AS2, they seem to like the higher pressure on the F6
#69 | |||
One time I found the tyres on one side were at a higher pressure than the other side, then realised that the sun was shining on the tyres on one side which caused the difference. |
#70 | ||
Formerly ST170ish
16" 45psi normal and 60psi fully loaded... LT tyres!
Didnt even know I needed 38psi on my FG 17"s... was wondering why the fronts are wearing the outers... dumb ***!
My bad attitude escalates in direct proportion to the amount of stupidity I am presented with!!! ![]() |
#71 | |||
Another interesting thing that's come up is the variance in service station tyre prssure guages and I know from a variety of local stations around where I live that there is a few p.s.i. difference between the highest reading and lowest. As posted above, i noticed quite a significant difference in handling in my car between 36 and 40 p.s.i.,to eliminate the service station pressure variables and to optimise handling and tyre life it would appear an investment in a high quality tyre pressure guage at home makes good sense. Any thoughts on which brand and where to buy it ? |
#72 | ||
I checked the max inflation on the side wall and it says 40psi. I don't think 40 psi is a correct pressure for day to day. If you don't know day you don't know. And if I didn't check? I would be a idiot yes, but the point is only give advice if you know your stuff.
When a car gets past you, you just want to go after them, you want to chase them down, you want to pass them. It's primal. But then there's another side to it, where you just completely forget about all the other cars on the track, and you feel like you're in another world. It's just you, at one with the road and the car. Eric Bana |
#73 | ||
Went to Repco today and bought a tyre pressure guage, just one of their generic branded ones.
Reads exactly the same as my preferred service station guage that I find the most believable so I think its all good. Tyres had lost 2 p.s.i. in two weeks and I could already feel the edge coming off the handling at 38 p.s.i. and went noticeably better at 40 p.s.i....looks like if you want to keep things spot-on re-inflation needs to be a weekly routine. |
#74 | ||
Between you and me (and the the forum) 4 PSI above recommended is a good place to start in my opinion.
2018 Ford Focus RS |
#75 | ||
Interestingly you guys might want to know that on a reasonably cold N.Z. day at 15 degrees celcius, just driving 5 km's to my preferred service station tyre pressure increased by 1.5 p.s.i. compared to cold un-driven pressure this morning.
On a hot day in Australia the increase could be significantly more and dramatically so if the drive is longer than that. Repco sell tyre pressure guages for as little as $10, money well spent in my opinion. |
#76 | |||
Interesting. Do your nights/mornings get cold over there? Down to 0°C or thereabouts? If so, are you able to check what the pressure is at cold temps v day time temp? Would be an interesting little exercise. Craig H
#77 | ||
^^ They do in winter mate but this spring morning was about 10 degrees vs yesterdays daytime temp of only 15 so not a significant difference there. I'd have to wait till next winter to get the info you're after mate.
Its surprising how quickly tyres warm up and increase their pressure especially if you're pumping some decent horsepower through them. |
#78 | ||
bought a set of continental tyres 6 months ago 235x55x18 running 36 psi, they have high wear on inside rear..Any idea what is causing this ,2015 TS TERRITORY only done 84.000kms
#79 | ||
38psi on 18's
40psi on 19's |
#80 | ||
