Old 23-04-2020, 09:59 AM   #1
Pauldw500
Default Get me home fixes???
Or...... just fixes that tie you over till part arrives...
I cracked the rubber on a Ford Ranger engine mount...
This held for over a week...
And recently I cracked the mount on the plate that gear stick connects to...
This is still in place.
I currently have a faulty oil cooler (oil getting into coolant mix) and have bypassed the cooler...
Still in place too...
Any other takers?
Pauldw500 is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2020, 11:01 AM   #2
jaydee
jaydee's Avatar
Default Re: Get me home fixes???
Time to trade her in.
I once saw a HD Holden with half a house brick for an engine mount and all tied up with nylon rope.
jaydee351
4DV8
jaydee is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2020, 11:03 AM   #3
FTE217
T3/Sprint8
FTE217's Avatar
blocks of timber used to do the job as well bolted right through.
Oh for the practical minds back in the day
Saving the buck hasn't changed but how haha
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
Old 23-04-2020, 11:05 AM   #4
Pauldw500
Yeah for sure... once funds permit... 😊
Old 23-04-2020, 11:16 AM   #5
WW2 in the UK apparently saw more than a few wooden pistons fitted.
Old 23-04-2020, 12:03 PM   #6
Electrolyte Burns
Fixed my busted accelerator cable with cable ties on my old Hi-Lux one time. Still there seven years later.
Electrolyte Burns is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2020, 12:30 PM   #7
I once fixed the accelerator cable that had perrished in my brothers car with a peice of metal bar i cut out of a fence and cable ties. The mechanic wondered why my brother wanted it replaced. Also sorted a boost leak in my old ranger with gaff tape and probably 200 cable ties. It worked, also got a good laugh when passed around at the mechanics.
Old 23-04-2020, 12:51 PM   #8
falconhell74
falconhell74's Avatar
Had my accelerator cable bust on my XCGS 302 about 70 km from home so I used a piece of electrical cable to the carb under the bonnet and through the drivers window for a hand held throttle ...... it was fun driving through town in a 4 speed manual
XC GS OLD SCHOOL MUSCLE
Audi A4 S-line quttro
Xc falcon
Previous fords-
xc falcon 500 ,250 x flow 3 speed
xc gs worked 250 x flow 4 speed
xa Fairmont 302 auto wagon
xb falcon 250 log auto 4 door
xb falcon 200 log auto ute
xc gs project - had to sell :-(
xc gs 302 4 speed 4 door
xc gs 351 auto 4 door
zf fairlane 302 auto
zk fairlane 250 x flow carb auto
zl fairlane 250 x flow EFI auto
xg ute , BA falcon dedicated gas
xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5
falconhell74 is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2020, 01:43 PM   #9
Tonz
do a youtube search 'bush mechanics' our local boys know how to keep things running...
Old 23-04-2020, 03:34 PM   #10
Chapter Four
Wrapped cigarette packet foil around a burnt out ballast resistor coil in a VJ Valiant to get it started.
Chapter Four is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2020, 04:10 PM   #11
roKWiz
Cabover nut
roKWiz's Avatar
Had a few of beauties driving the motorhome, best ones are driving down from Coffs to Wangaratta and got within 3km from base, snapped alternator bracket, loosing water pump, belt in the process causing a overheat. Pulled the bracket, screwed brick wall ties to either end, reinstalled with nylon rope I had as a temp fan / alternator belt for the long 3km drive home.
Blew a front steer tyre on the Buckets Way, breaker bar wasn't getting the wheel nut loose and could not get the jack under the front axle to lift anyway. Tyre was holed and toasted so picked heaps of wet grass on the side of the road and stuffed it into the hole, managed to drive to Nabiac (at about 10km/h)) for a new tyre. Tyre guy said I saved the split ring wheel by doing so and was impressed.
The wet grass tyre trick I had used while out mountain biking and pinch flatting several tubes.
Down at Koroit I managed to jam the gearbox up, no gears, entering an overnight stop at the CP, next morning with wire got one gear working (3rd) and was heading for a truck mechanic in Warnambool, spotted one of his worker in a ute so communicated with him (hand gestures) that I was heading there in only one gear which meant I couldn't stop so he escorted me in avoiding traffic straight to the yard.
Old 23-04-2020, 05:04 PM   #12
Aluminum foil gasket from power steering hose to steering box.
Old 25-04-2020, 05:45 PM   #13
lance
lance
lance's Avatar
Used the peak of a baseball bat cut to shape, for a thermostat gasket on the Ford D series engine in my parents’ boat. It was in there nearly a year.
1971 XY GTHO replica electric blue 4spd black trim Sold
1984 XE Esp Fairmont Ghia 6cyl Sold
1984 Xe Fairmont Ghia 6cyl Efi Sold
1966 Xp deluxe sedan Sold
Mk2 escort sedan 1600 Sold
Mk3 cortina 2 litre Sold
1975 Xb Falcon 500 250/ column auto 94000 kms
Current
lance is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2020, 07:22 PM   #14
Lugh
Lugh's Avatar
Ratchet strapped the front axle of a Landcruiser to the leaf spring after the u bolts snapped. It located fine on the centre bolt and drove like nothing ever happened.
2006 BF RTV
1980 HZJ 60
Lugh is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2020, 07:30 PM   #15
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
Did similar but snapped the whole diff banjo in half, tied up with boat anchor chain, drove 200kms on dirt back to civilization very slowly...
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2020, 08:51 PM   #16
Burnout
Falcon RTV - FG G6ET
Burnout's Avatar
Met a bloke on the Nullabor in'72, who had a wooden piston in his Norton. He had made it earlier in the year out of Gidgee up in SW QLD.
May still be going, considering how hard that timber is, having hit it with an axe one time.
BAII RTV - with Raptor V S/C.
RTV Power
FG G6ET 50th Anniversary in Sensation.
While the basic Ford Six was code named Barra, the Turbo version clearly deserved its very own moniker – again enter Gordon Barfield.
We asked him if the engine had actually been called “Seagull” and how that came about.
“Actually it was just call “Gull”, because I named it that. Because we knew it was going to poo on everything”.
Burnout is online now   Reply With Quote Multi-Quote with this Post
Old 26-04-2020, 07:15 AM   #17
roKWiz
Cabover nut
roKWiz's Avatar
Sound like Sth American Purple Heart, beautiful hard boat building timber of old. Polishes up like stainless steel, very rare now days. I have a small sample at home.
Old 26-04-2020, 07:18 AM   #18
roKWiz
Cabover nut
roKWiz's Avatar
Hi Lance, was that a D series marine conversion or a Ford "Lees". Beaut diesels and very reliable the Lees.
Old 26-04-2020, 07:22 AM   #19
They built boats of Purple Heart? Dear as poison now - check it out.
Old 26-04-2020, 07:44 AM   #20
roKWiz
Cabover nut
roKWiz's Avatar
If you can find it, dear as poison alright.
Mainly ribs and deadwood keels, some below the water planking to keep worm at bay, rubbing strakes and spars. A bit heavy for standing spars but idea for bowsprits, bumpkins and davits.
Old 26-04-2020, 07:53 AM   #21
Charliewool
Bolt Nerd
Charliewool's Avatar
Nazareno or corazón Purpura it’s called here... Native to Costa Rica and central america..
Ticos use ir for everything from plates, bowls, ornaments... to bigger stuff like table tops and bed heads... Beautiful when highly polished
Though I’ve never seen a boat made out of it?.. Maybe too dense?
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4
Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD
Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD
2 wheels.. 2015 103ci HD Wideglide.. SOLD
SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida!
(Ex Blood Orange #023 FPV Pursuit owner : )
Charliewool is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2020, 07:55 AM   #22
Rambunctious
Waiting to collect a truck tailshaft at the driveline outlet at Brendale years ago, and the mechanic had a nice Holden HZ V8 Sedan on the hoist looking around under it.
Turned out the owner had done a run around Lakeside race track after getting the tailshaft balanced and bought the car back because of a vibration, which the mechanic was at a loss to fix, until I pointed to the rear gearbox mount being a block of timber.
Rambunctious is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2020, 08:06 AM   #23
roKWiz
Cabover nut
roKWiz's Avatar
Yeah being a boatbuilding timber and building a compete boat out of it would be two different things.
My old boat had ironbark scantlings with NZ Kauri planking (carvel). In a trawler of 34 foot it would be too heavy for its own good if it was all built completely of ironbark.
