Old 25-07-2020, 06:16 PM   #1
PIGNUTS
Default F Truck compliance plate
Hi All,
A mate has asked me to decode his compliance plate, but i'm not having much luck on google.
Is anyone able to decode the plate please ?
Thanks and cheers Pignuts
PIGNUTS is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2020, 10:05 PM   #2
Tassie f100
Default Re: F Truck compliance plate
If you post a photo that can be seen and read you just might get some help
Tassie f100 is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2020, 12:13 AM   #3
Crazy Dazz
It appears to be a Ford Australia Identification Plate
At a rough guess, I would say this was from the 60s...
Prefix: AK1KGL A means it was manufactured in USA but assembled locally, "K" indicates it was assembled in Sydney.
1K Is the model, I believe that is an F700.
GL is the year and month. I believe it is May 1967.
SERIAL: 24288 I believe that units of each model were number sequentially, so you could probably tell more from this if you knew the allocation.
SIDO: 4Q3254 This is the unique dealer's order.
MODEL: 73753T?? 73753 Indicates it was a F700 Cab-Chassis with the 194 inch wheelbase.
ENGINE: T Not 100% but I believe this was the FT 330, a heavy duty version of the FE.
TRANS: F Borg-Warner 4spd T-18 h/duty truck transmission
R AX: H
FR AX: G
PAINT: E White
TRIM: Y "Palomino"
Brake Booster: D
GVW: 23000 pounds
NET HP: "" I believe it was 190bhp
RPM: "" @4,000rpm
SVO: ""
Crazy Dazz
Kicking Hippies in the Balls since 1966
Old 26-07-2020, 11:56 AM   #4
Paull
P6 LTD
Paull's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For all the hard work performed around paint, trim, engine codes in the Classics section. General all round knwoledge and willingness to impart on others
It's all here
Paull is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2020, 03:57 PM   #5
PIGNUTS
Thanks for your useless answer ya clown
Old 26-07-2020, 03:58 PM   #6
PIGNUTS
Originally Posted by Paull View Post
It's all here
Thanks heaps mate, appreciate it. Cheers
Old 26-07-2020, 03:59 PM   #7
PIGNUTS
R AX: H
FR AX: G
PAINT: E White
TRIM: Y "Palomino"
Brake Booster: D
GVW: 23000 pounds
RPM: "" @4,000rpm
SVO: ""
Thanks so much mate, appreciate it. Cheers
Old 26-07-2020, 04:06 PM   #8
Tassie f100
[QUOTE=PIGNUTS;6470341]Thanks for your useless answer ya clown [/QUOTE. Well if you hadn’t posted such a tiny little photo.I might have been able to read it and help.you .A.H
Old 26-07-2020, 04:07 PM   #9
wodahs
wodahs's Avatar
i hate to say but it wasnt a useless answer and if youd posted a better pic some of us may have been able to assist earlier as i couldnt even read the plate my self so why go to the trouble to help
i even know where and how to access Paulls treasure trove of info and had seen your post prier to any other comments
and with replys like this , this is why help can be hard to get at times
yes still (as money n time permit) doing the
rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually
just remember don't be afraid to try something new.
Remember, amateurs built the Ark...Professionals built the Titanic!
I have taken up meditation... at least it's better than sitting around doing nothing !!
wodahs is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2020, 04:21 PM   #10
Rallye Sport
RS The Faster Fords
Rallye Sport's Avatar
Wasn't too hard to clean it up a bit and help the guy out.
Mk1 GT Cortina Project.
FG XR50 Daily.
Old 26-07-2020, 04:36 PM   #11
Franco Cozzo
Franco Cozzo's Avatar
Wow! It's THE Adolf Hitler!
How long have you been a member of AFF for?
Old 26-07-2020, 04:45 PM   #12
Tassie f100
Just a little bit longer than Dirty Harry!!
Old 26-07-2020, 06:55 PM   #13
Itsme
Experienced Member
Itsme's Avatar
Well not everyone is computer savvy in doing this.
I think the OP was bit too harsh with his comment to Tassie f100, did not see tassie post being abusive.
Old 26-07-2020, 07:08 PM   #14
Rallye Sport
RS The Faster Fords
I understand that, it wasn't long ago that I though image hosting and editing was voodoo, until someone on the forum was good enough to run through it with me.
Turns out it takes as much time to help the guy out, giving some back in a sense than it does to sledge him on it.
FG XR50 Daily.
Old 26-07-2020, 07:27 PM   #15
Paull
P6 LTD
Paull's Avatar
Apologies for stating the obvious, but, if you don't already know "Ctrl + roll up" increases page size. That's all I did.
Old 26-07-2020, 07:29 PM   #16
Tassie f100
Not on an Ipad
Old 26-07-2020, 08:24 PM   #17
wodahs
wodahs's Avatar
i know where to find you treasure trove but sorry i didnt know this
the things an ol' f'rr learns even as we loose other functions
but as i couldnt read it thats why i kept silent rather than ask for a repic
Old 01-08-2020, 09:13 AM   #18
PIGNUTS
Just wanna say THANKS to the guys that helped out.
