Old 11-04-2006, 08:11 PM   #1
22richard
Default water in fuel tank
hi i got a ed with missing problems ,it will idle for hours parked on the level it will rev up slight miss,but park the car with the left hand side of the on a angle the fuel tank outlet is on the left ok leave ideling for 5 minutes jump in and rev off or try to ,the miss is one hell of a rough put your foot down and it just coughs it wont behave well at all ,would i be rigth that if the tanks has some water in then parked on the angle it will suck the water first it being heavier than fuel,it takes a long time after doing that i suppose the water gets in the filter ,anybady else had trouble
grahaml
22richard is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2006, 08:13 PM   #2
ebxr8240
Performance moderator
ebxr8240's Avatar
Try adding some metho to tank.. Other than that drop tank and clean..Then replace fuel filters...Graeme....
Daily driver GTE FG..
Old 11-04-2006, 08:33 PM   #3
frost
frost's Avatar
Haha I got water in my tank to, it seems now I have to go the whole hog
Fuel Tank, Pump, Filter and Injectors!
frost is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2006, 08:47 PM   #4
gthofan
Gunna girlie-man
gthofan's Avatar
spot on there my friend. works a treat, metho is nearly pure ethanol, it will raise combustion in the petrol. works well in lawn mowers aswell.
WADE CAMS-- UNLEASH THE POWER!!
<INSERT WITTY SIGNATURE HERE>
Daily- 05' BA futura... work done.
Cruiser- 85' VK berlina... more work done
gthofan is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2006, 08:51 PM   #5
XR8Chic
I swear its all stock!!
XR8Chic's Avatar
you dont need to drop the tank - you can just drain it out from the access to the tank in the boot.
I had to do that once in my EA (stale fuel), and once in my XR (the only time I ever used caltex vortex).
Not too hard to do, just really smelly.
1993 ED XR8
2006 BF GT
2011 FG XR6 Ute Limited Edition
XR8Chic is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2006, 09:32 PM   #6
oyob2003
Yes metho, metho and water mix unlike water and petrol.
oyob2003 is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2006, 10:24 PM   #7
22richard
Hi xr8 chic
yes i have only had 3 full tanks of caltex vortex and presto i have this problem.i only pick it might be water cause when i visited gympie the other day it is all hills and hey the bloody car would hardly climb the hill floor the pedal and it just died
thanks.graham shall let you know the outcome
