Old 05-10-2020, 06:12 PM   #1
Crazy Dazz
Default New Type Headlight Repair Kits?
Has anyone tried one of the new type of headlight repair kits?
To get rid of the yellowing & crazing on polycarbonate lights.
An example is here: https://www.aliexpress.com/item/4000331800745.html
(This one can't be shipped to Australia, possibly due to the fluid.)
As far as I can tell, the fluid is placed in the heating vessel, which vaporises it, and you then direct the output at the lense.
Apparently the Russians love it: "It's just a gun. Unreal bull****. Magic is real! 200% happy. Delivery yes 4 days. My best buy on Alice."
What I'm not clear on is whether this is just the coating, and it still requires the wet &dry polishing beforehand?
And if not, are the effects long-lasting, or is it like the WD40 trick
Crazy Dazz
Kicking Hippies in the Balls since 1966
Old 06-10-2020, 10:06 PM   #2
happy1
Default Re: New Type Headlight Repair Kits?
yes it says in the comments that it requires sanding, starting with 400, then finer and finer until 2000 wet paper, before applying the product.
This may work, but I also believe 2k clear coat may work on headlamp lenses.
happy1 is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2020, 01:42 AM   #3
oldel
It's probably similar to the acetone trick. I sanded and polished my lights but there's been chat here and I've seen videos of just using acetone. It melts the plastic so well that if you do it right you get a perfectly clear lens without sanding.
oldel is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2020, 07:51 AM   #4
ivorya
Mad Scientist!
ivorya's Avatar
I've also seen people using toothpaste as well.
It seemed to work well, just not sure of the camera trickery!!!
ivorya is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2020, 01:56 PM   #5
Crazy Dazz
That's what one purchaser has posted, which would make it no different to conventional methods.
My assumption is that this is some method designed to actually "restore" the damaged surface, rather than simply abrading it.
Crazy Dazz
Old 07-10-2020, 02:12 PM   #6
hayseed
From What I've seen they're only a Short term Fix used by Smash Repairers & Used Car Yards To Tart something Up to get It Out the Door looking OK..
hayseed is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2020, 02:43 PM   #7
pcman
it is acetone vapor, youtube it for a diy setup, it is also commonly used for finishing 3d printed parts to make them smooth
pcman is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2020, 03:22 PM   #8
boss351290
I have found that the best way to fix clapped out faded headlights is to replace them with new ones
boss351290 is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2020, 05:44 PM   #9
GasoLane
Former BTIKD
GasoLane's Avatar
Mine are $700 a throw so that wont be happening
Old 10-10-2020, 07:34 AM   #10
roKWiz
Cabover nut
roKWiz's Avatar
Yes Gaso, life's a struggle driving a Mercedes.
Old 10-10-2020, 10:00 AM   #11
GasoLane
Former BTIKD
GasoLane's Avatar
Old 10-10-2020, 11:01 AM   #12
Franco Cozzo
Franco Cozzo's Avatar
To put it into perspective the OEM HID headlight assemblies for my Focus cost circa $3000 for the assemblies, two ballasts and two globes
Just wait until we're replacing LED headlight assemblies as the low beam lights go dull, I'm thinking 4 figures a pop :shock
Anyone here got LED down lights at home? They still work they just put out hardly any light as they age, same with LED spotlights and work lights, I'm extrapolating that the LED low beams getting around these days will do something similar.
Old 10-10-2020, 11:52 AM   #13
Itsme
Itsme's Avatar
Stop buying your LED lights from the $2 shop and you will be ok.
Itsme is online now   Reply With Quote Multi-Quote with this Post
Old 10-10-2020, 02:26 PM   #14
roKWiz
Cabover nut
roKWiz's Avatar
I think my headlight cost me 24 bucks each and that's the premium brand Hella.
Old 10-10-2020, 02:44 PM   #15
Crazy Dazz
I didn't realise Hella made Candles.
Crazy Dazz
Old 10-10-2020, 02:47 PM   #16
Crazy Dazz
So why do I need it vaporised?
Crazy Dazz
Old 10-10-2020, 03:45 PM   #17
Franco Cozzo
They're OSRAM ones but OK
Old 10-10-2020, 03:49 PM   #18
Franco Cozzo
They sure do, I think everyone here has experienced EF/EL Falcon headlights, they were designed by the mighty Hella.
They even go yellower than me teeth after a while too
Old 10-10-2020, 05:04 PM   #19
roKWiz
Cabover nut
roKWiz's Avatar
Yeah, I didn't say I could see anything.
Old 11-10-2020, 02:59 PM   #20
boss351290
Well if you can’t afford new ones the best option is to rub them with 2000 wet and dry with heaps of water and dishwashing liquid as a lubricant then get the buff on them with polish on a foam or lambs wool buff pad. They will come up good. Just don’t rub too much
Old 11-10-2020, 03:20 PM   #21
GasoLane
Former BTIKD
GasoLane's Avatar
I only have problems with the left side with the Car-Bra rubbing (the right side is new thanks to a Roo ) and I do similar to what you mention, but thank you anyway.
Old 11-10-2020, 05:09 PM   #22
Crazy Dazz
Oh, but you know which headlights are still pristine? Despite sitting in the weather for the last decade?
Yep, the AU.
Crazy Dazz
Old 11-10-2020, 05:46 PM   #23
pottery beige
Yep, the AU.
muchly prefer bone cancer thanks
pottery beige is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2020, 06:23 PM   #24
GasoLane
Former BTIKD
GasoLane's Avatar
Yep, the AU.
Except the Fairlane/LTD ones
