Old 26-08-2020, 09:32 PM   #1
jakkes
jakkes's Avatar
Default master cylinder for 6/4 brembos
When up grading a 2004 BA falcon to 6/4 brembo calipers do you need a FPV master cylinder to operate them properly or even a different booster???????
GIMME FUEL, GIMME FIRE, GIMME THAT WHICH I DESIRE.
BA falcon XT mkII, 5.4lt, 5sp,
Y-code, xy windowless pano, 3 on the tree manual.
re-shelled xy falcon GT, manual.
1980 honda CX500 scrambler/dirt tracker
jakkes is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2020, 01:05 PM   #2
Blue_XR
Blue_XR's Avatar
Default Re: master cylinder for 6/4 brembos
I beleive the master cyclinder in the FPV's was the same as a regular falcon. I also have the parts to upgrade to 6/4 brembos, just need the time to change it all over.
I am curious if a change is required for the master cylinder.
YouTube channel: Modaufy Garage
https://www.youtube.com/c/ModaufyGarage
Blue_XR is online now   Reply With Quote Multi-Quote with this Post
Old 27-08-2020, 08:29 PM   #3
jakkes
jakkes's Avatar
When I first put them 6/4 brembos on this BA XT falcon they work great but for a while now they don’t seem to bit as good and I’m getting the ABS come on at random times mostly at light pedal input????.
I understand my cars ABS is tuned for a stock braking set up.... but it never used to do it so just asking in case I need to bring other parts up to spec
Anyone got ideas on the ABS coming on??
Old 27-08-2020, 10:42 PM   #4
GTLEGEND
There were different boosters and master cylinders in BA to BF series but had nothing to do with Brembos or standard brakes. It was more to do with if you had ABS, DSC, traction control etc.
Old 27-08-2020, 10:53 PM   #5
arronm
BA/F6 BF/F6 SSV/R TTG
arronm's Avatar
FPV have different master cylinder for brembo combo. Its the crack pressure difference between front and rear.
BA BF FPV starter button repairs. PM me.
Nizpro equipped and Tuned by the BEST in the west
Xtreme Ford Tuning
479RwKw Fuel limited, more pumps and power too come.
F6#0507 & #0639 Pro racer and Tech expert
NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below.
https://youtu.be/oa4IfguGQ-A
arronm is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2020, 08:51 AM   #6
GTLEGEND
Below are all the combinations of brake master cylinders for BA to BF Falcon including FPV..
Old 29-08-2020, 12:21 AM   #7
moey747
Do you know the P/N?
moey747 is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2020, 06:33 PM   #8
GTLEGEND
All the BA/F part numbers are listed below, there was nothing unique for an FPV, it is more about the spec of ABS/traction control etc..
Old 06-11-2020, 11:27 PM   #9
jakkes
jakkes's Avatar
i ended up fixing my issue i had some metal shavings on one of the sensors cleaned them up and all good now
