Go Back   Australian Ford Forums > The Sales Yard > Spare Parts and Other Accessory Items > Genuine Ford Parts
Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member.
Old 01-12-2020, 09:04 PM   #31
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Default Re: Genuine Ford Parts
Genuine OEM fuel filter to suit AUII XR8 sedan please.
Old 01-12-2020, 10:01 PM   #32
GTLEGEND
Originally Posted by GasoLane View Post
Hi GT. are new headlinings still available for B series utes?
Hi mate, no longer available.
Old 01-12-2020, 10:11 PM   #33
GTLEGEND
https://www.ebay.com.au/itm/Genuine-...frcectupt=true
Example above. I can only get for $22 + freight if required.
Old 01-12-2020, 10:17 PM   #34
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Thanks mate, do you know if the one you linked fits the 5L V8, as it only lists the 6cyl ?.
Also I forgot to ask, a genuine Ford Motorcraft power steering pressure switch to suit the above mentioned vehicle.
Regards.
Old 01-12-2020, 10:46 PM   #35
GTLEGEND
Regards.
Yes both 6 cylinder (with IRS) and V8 take the same fuel filter in AU Series, its the non IRS 6 cylinder that is unique.
Power steering switch that sits in the rack is available, $100 plus freight.
Old 02-12-2020, 02:30 AM   #36
Cav
HUGH JARSE
Cav's Avatar
Hey GT
I am after a silver spear insert driver's door 2008 FG XR6 ute.
Cav
Cav is online now   Reply With Quote Multi-Quote with this Post
Old 02-12-2020, 09:00 AM   #37
GTLEGEND
Originally Posted by Cav View Post
Hey GT
Cav
Hi Cav,
Will need your VIN to confirm as there are a few different coloured spears available pending on a few things. If its the standard satin silver spear for XR then it is no longer available. There are a few others that are though.
GT
Old 02-12-2020, 12:49 PM   #38
Cav
HUGH JARSE
Cav's Avatar
Hi Cav,
GT
Yes I got the same news from the Ford dealer in Rocky.
The driver's one in my ute which I have only had for a short while is black.
I took it off and it is silver that has been painted black rather poorly - so I am going to sand it back and repaint it silver.
What could possibly go wrong?
Cav
Gratuitous ute shot follows ...
Old 02-12-2020, 01:47 PM   #39
GTLEGEND
Cav
Nice ute!!
Old 04-12-2020, 10:39 PM   #40
Dingo
Ford T3 Partsologist
Dingo's Avatar
Careful - There are 2 types of Fuel Filters
With IRS - AFG55 / BG 9155 B or With Out IRS - AFG60
2002 Blueprint T3 TE50 Manual Koni Suspension # 161
T-Series Club of Australia - www.tseriesclub.org
Dingo is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2020, 10:44 PM   #41
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Originally Posted by Dingo View Post
Careful
With IRS - AFG55 / BG 9155 B or With Out IRS - AFG60 they use different Fuel Filters
Thanks mate, I need the one for IRS.
I believe the link that GT sent above was the one I need, it suits IRS.
Old 05-12-2020, 12:11 AM   #42
FairmontGS
WT GT
FairmontGS's Avatar
Default Genuine Ford Parts
Hi GT, do you have indicative pricing for the 19 x 9.5” rear rims and caps in standard grey finish as per FGII RSpec and FGXR8 to suit 05/2011 GT?
Asking for a friend
Sent from my iPad using Tapatalk
FairmontGS is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2020, 12:23 AM   #43
GTLEGEND
AU2 XR8 only came with IRS, so there is only one option...
Old 05-12-2020, 12:40 AM   #44
GTLEGEND
Asking for a friend
FG2 GT Rspec had a choice of 2 different rear wheels 19x9 with red inserts ($960 each) or 19x9 with black insert ($930 each), GTF Style rear 19x9 ($870 each). The FGX XR8 Rear 19x9 wheels are $745 each. Centre caps are $171 each. Will need to add freight to any of the above.
You will need to be very specific about which wheel you are exactly after, if you have a picture or part number, that will also help.
Old 05-12-2020, 05:57 PM   #45
FairmontGS
WT GT
FairmontGS's Avatar
Thanks GT. That's given me some things to think about. I'm up for new rear rubber soon and thought it might be time to go for the wider rims.
I need the rims that would match the exact style of the original 2011 rims in finish. I'll do some research.
Old 06-12-2020, 02:51 AM   #46
GTLEGEND
For Roostercam..
Let me know what part you are referring to..
Old 06-12-2020, 11:34 AM   #47
GTLEGEND
Old 07-12-2020, 10:40 AM   #48
Dingo
Dingo's Avatar
G’day GT
Can I please have a part number for a Universal Joint rego 5600MO
As on Microcat there is no part number listed for a universal joint for a T3 TE50 2002 you have to buy a complete tail shaft...........
Thanx Darren
Old 07-12-2020, 02:40 PM   #49
GTLEGEND
Hi Darren,
From what I can work out the universal joint should be BA 4635 A.
Cheers,
GT
Old 07-12-2020, 03:00 PM   #50
Dingo
Dingo's Avatar
Gday GT
yeah i thort as much , just wanted to check as MC only shows up to 31st of October 2001
thanx again
Aaaaarrrrrrrrrooooooooooooooo
Old 07-12-2020, 03:37 PM   #51
GTLEGEND
Gday GT
thanx again
Do you know if they are physically different? Maybe compare the part number supplied with one off a vehicle.
You might find they are the same?
Old 08-12-2020, 10:14 PM   #52
dead_man00124
Complete set of rubbers for the doors?
doors and frames
S1 AU Fairmont
also very long shot, can you tell me if the tailshaft is different on a T3 TE/TS50 manual is different to the XR8 manual sedan?
dead_man00124 is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2020, 12:02 AM   #53
GTLEGEND
doors and frames
S1 AU Fairmont
From what I can find, I could only possibly get both front and RHR on door seals. LHR and all door opening on body seals are no longer available. Just getting confirmation and pricing on the three said seals and will advise.
Yes the shafts are different from a T3 T Series Manual and a XR8 manual. The T series us shaft TAU3 4602 A and the XR uses ERT 4602 A.
Get back to you about the seals.
Old 09-12-2020, 02:04 PM   #54
dead_man00124
thanks mate, would be appreciated.
Old 09-12-2020, 07:27 PM   #55
GTLEGEND
Can get both front on door seals for $45 each and the RHR on door seal for $115 (not sure why the rear is so much more?). Freight of $20 on top if required.
PM me if your interested.
Old 12-12-2020, 10:27 PM   #56
Espec
Hi GT can i get a price on a SY territory rear console bin latch part no 5R7ZA11675AASH
Cheers Eric
Espec is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2020, 10:41 PM   #57
GTLEGEND
Cheers Eric
Hi Eric,
$47 + freight if required.
Cheers,
GT
Old 12-12-2020, 11:07 PM   #58
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Hi GT,
Are the rear bleed screw in the brake calliper's still available for AUII XR8 standard PBR brakes.
Also the rear exhaust rubber hanger ?, although I have a Herrod exhaust on it now but not sure if they used the genuine rubber mount or not ?.
Cheers.
Old 12-12-2020, 11:22 PM   #59
GTLEGEND
Hi GT,
Cheers.
Hi Galaxy XR8,
Brake bleed screw is not available from Ford, how ever I am sure they are available from aftermarket brake specialists or auto stores.
Yes rear rubber hanger for AU2 XR8 is still available, $10 + freight each.
Cheers,
GT
Old 12-12-2020, 11:29 PM   #60
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Hi Galaxy XR8,
Cheers,
GT
Cheers, mate, does the rear rubber hanger have a part number on it or pic, I'm trying to establish if the one I have that is stuffed is a genuine one or not, I assume even though Herrod did the exhaust that it would have been designed around all the original hangers etc, and therefore theoretically should use the existing rubber mount.
