Old 06-01-2021, 11:20 PM   #841
Pis-ton broke
Pis-ton broke's Avatar
Default Re: Mowing ..
Originally Posted by hayseed View Post
Kikuyu, grows good in the Winter.
no mate, it doesn't. it grows in heat and humidity, its an african species .
Pis-ton broke is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2021, 11:23 PM   #842
Plague of sewers and septics. Hate it passionately.
Old 07-01-2021, 07:51 AM   #843
roKWiz
Cabover nut
roKWiz's Avatar
Originally Posted by Citroënbender View Post
Could it be bentgrass?
Is bent when I drive on it.
Comparing pictures from previous years, its at its greenest from May to October and doesn't yellow at all during that time.
Considering it will regularly get down to -4 overnight with heavy frosts.
Old 07-01-2021, 11:12 AM   #844
Kikuyu is great for paddocks.
Old 16-01-2021, 12:24 AM   #845
danzvtil
danzvtil's Avatar
Bought a husky line trimmer today on DFGs advice ( sorry mate, I can’t seem to reply to your DM), got the 322L model which is mid range, below the professional range , in the landowner range. It’s .5kg lighter than the equivalent stihl straight shaft model.I’ll give it a try tomorrow and report back. My new business cards arrived today, I now have a PO Box and an accountant. I guess this is what being a grown up feels like ��
____________________
2024 TOYOTA HIACE
2019 LDV G10-GONE THANKFULLY
2009 Mitsubishi Express-GONE
2011 Honda Jazz
danzvtil is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2021, 08:02 AM   #846
roKWiz
Cabover nut
roKWiz's Avatar
Good on you. Once you enter that mindset, work will naturally flow your way.
Old 16-01-2021, 10:03 AM   #847
Tonz
not promising anything ....what part of Adelaide do you prefer to cover.
Old 16-01-2021, 11:58 AM   #848
Work Horse
Budget Racer
Work Horse's Avatar
I have always used Sthil brush cutters, but I am becoming increasingly disappointed with the build quality of some resent Sthil purchases. My blower Sthil BG 86 is so bad I will not buy another Sthil blower. I will be looking at Husqvarna gear next time I think.
Does Husqvarna do an automatic line feeding head for brush cutters like the Sthil supercut 20-2? That is one feature of the Sthil I like.
12.1@112Mph 285rwkw on n2o Cleveland Power
Work Horse is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2021, 07:06 PM   #849
I was very much a Stihl man but I can echo your sentiments.
I have had a few BG55 / BG 86 blowers. I currently have two because a few years ago the oldest one seemingly seized. I replaced with a new one and threw it in the shed until I discovered that there is a pretty simple reason/fix for this problem.
https://www.youtube.com/watch?v=RGwvi0Q8zqA
Seems that the three bolts that attach the engine to the blower body work loose over time, jamming the flywheel. Stihl don't use thread lock for these bolts.
So now I have two running BG86's, one is hard to start in hot and humid weather, the other has a failed ignition switch and a dodgy starter.
Will definitely looking at my options when it comes time to replace these.
Old 16-01-2021, 07:40 PM   #850
Rallye Sport
RS The Faster Fords
Rallye Sport's Avatar
Mechanically I can't fault the Stihl equipment but I too have noticed the drop in finish quality, the casings are thinner, you may aswell take the plastic exhaust guards off and store it because it won't see the day out. We've also had drama's with the choke switches breaking.
We've had a few demo's come through of late. I bought a BGA57 electric blower on the spot after using one for a few minutes, its a gem of a thing.
The other one that really impressed me was the Husky electric pole saw, instead of shaft drive it has the power head at the cutting end. It was smooth powerful and light. I'd like to trade our Stihl shaft drive for one.
Oh and best of luck Danzvtil I've got no doubt you'll do well
Mk1 GT Cortina Project.
FG XR50 Daily.
Old 16-01-2021, 08:39 PM   #851
I noticed this at Bunnings today. Has anyone tried one?
It doesn’t seem to be consistent with a “DIY” workshop!
Old 16-01-2021, 09:40 PM   #852
I want to see what it would do that synthetic grass!
Old 16-01-2021, 10:24 PM   #853
Rallye Sport
RS The Faster Fords
Haha! I like you're sense of humor...
Reminds me of the folks "Robo-vac" The border collie used to nudge it into a corner then spend all day holding it there Not sure if i'd let her near one of these though.
FG XR50 Daily.
Old 16-01-2021, 10:39 PM   #854
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
My grass has died off in certain areas, which I thought quite odd considering that Sydney had a ton of recent rain - followed by a heap of heat.
I fed it some Number 17 lawn food and kept the water on it.
I think I found the problem. Not enough top soil and the ground below the grass is very heavily compacted - it is essentially like laying the turf over cement.
The recent heat has dried it out and the water was not absorbed due the the hardness of the ground.
I've gone at the areas with a pick and tried to break up as much as I can - very hard to do.
I've also been spreading around some fine top soil to fill in the holes and hopefully build up some thickness over time.
Has anyone used this product, I may give it a go? 1 bottle should be enough:
https://www.bunnings.com.au/groundbr...eaker_p0013635
I figured for $15 it's worth a try.
___________________________
Old 16-01-2021, 10:44 PM   #855
Has anyone used this product, I make give it a go? 1 bottle should be enough:
I have used Groundbreaker before with good results, although was for planting a tree. Can't see why it wouldn't work for you application.
Old 16-01-2021, 10:58 PM   #856
I’d also be forking it, if you can drive it in (and get it back out!). Push it in well, wiggle, pull out, repeat. Water well after. Clay breaker works but not fast.
Old 16-01-2021, 11:11 PM   #857
Rallye Sport
RS The Faster Fords
Looking at the MSDS this is about a 5% mix of sulphuric acid, it'll help break down organic matter but thats about it.
https://2ecffd01e1ab3e9383f0-07db7b9...2b2959b68f.pdf
If you're on sand use soil wetter, if its loam or clay keep punching holes and filling them with sand.
Or for a no punch method add gypsum and water it in to soften clay soils.
FG XR50 Daily.
Old 16-01-2021, 11:12 PM   #858
danzvtil
danzvtil's Avatar
I’m north east suburbs.
2024 TOYOTA HIACE
2011 Honda Jazz
Old 16-01-2021, 11:23 PM   #859
danzvtil
danzvtil's Avatar
Now that you mention it, my BG86 which isn’t that old, is feeling tired. It took my echo 7 years with only a few new spark plugs to feel the same.The only way I can shut it down is to choke it, the lever isn’t working, might send it in for a service.
So I took the huski out on my lawns this morning, and went straight back to the stihl. Today’s lawns were all vertical cut edges, and I’m real particular about how good they look. I’ll have to practise on my own lawn until I’m comfortable.
The 2 things I need to get used to is it spins anti clockwise and the guard is huge, so I can’t see what I’m doing.
2024 TOYOTA HIACE
2011 Honda Jazz
Old 17-01-2021, 12:59 AM   #860
Yellow_Festiva
Where to next??
Fork will stand no chance. Not only is it rock hard its full of rocks.
Will just belt at it with the mattock till I've had enough and hope that works.
Sent from my SM-G973F using Tapatalk
Old 23-01-2021, 02:45 PM   #861
John 13
Typical Bunning's marketing and questionable ethics. You never know old 45 may get a job there.
John 13 is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2021, 06:40 PM   #862
I got sent this photo of some quality work carried out by a Jim's Mowing franchise.
These guys installed instant turf OVER the existing lawn.
I hope they were reported back to head office because I know that sort of job would not have been a cheap. Or perhaps that is why they got the job in the first place?
Old 26-01-2021, 06:43 PM   #863
Pay peanuts get monkeys as the saying goes.
Old 26-01-2021, 06:49 PM   #864
GasoLane
Former BTIKD
GasoLane's Avatar
I wonder if the same franchisee does car detailing.
I'm curious to know how much foam got on the upholstery
Old 26-01-2021, 06:53 PM   #865
The thought of Jim's Detailing..............
Old 04-02-2021, 08:29 AM   #866
383hq
Who'd a thunk 63,000 facebook members on a lawn site
https://www.abc.net.au/news/2021-02-...roups/13116316
383hq is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2021, 10:55 AM   #867
Work Horse
Budget Racer
Work Horse's Avatar
My BG 86 is now 5 years old it did the same thing more than once
Also;
-Bolts attaching head and crankcase became loose
-Carb return spring broke, not a service item!! The guy at the Sthil shop I have used for 25+years took me behind the counter to show me the parts he could order. Broken return spring=new carb at $100+. I ended up with an ebay carb for $28 delivered in two days that works fine but for how long?
-Clamp system holding nozzle on failed so is now held on with self tappers
- Muffler continually came loose, so very strong loctite applied to the bolts the last time it happened. To my utter disbelief the muffler came loose again this week. On inspection bolts still firmly loctited in place, they are never coming out but the muffler has broken away from the mounting.
Sorry
So I am in the market for a new blower, what do you guys recommend?
I have had several Sthil blowers but have been burned this time (let it go Work Horse)
I have had Echo blowers in the past and they went well.
Old 04-02-2021, 12:42 PM   #868
GasoLane
Former BTIKD
GasoLane's Avatar
I'm not one, mine will have to be done (again!) today as rain predicted for tomorrow.
I'm considering replacing the grass with green concrete
Old 04-02-2021, 01:02 PM   #869
Mechan1k
Mechan1k's Avatar
They probably one have:
1 bucket
1 sponge
1 broom
1 chamois
Old 04-02-2021, 06:40 PM   #870
383hq
Greek style
Round up and concRete (for R&R)
